Results 1 to 19 of 19
    Apr 2012
    94
    jUSt fitted H&R and perch plate, question though
    Just today fiited H&R and front perch plates, car looks shweet (photos to follow) but camber seems very severe at front and steering feels weird, normal or not?
    Jan 2013
    Moray
    228
    Have you had the car's geometry set up?
    Apr 2012
    94
    nope, was gonna wait till a fitted spacers which i havent ordered yet
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by schmergal View Post
    Correct me if I'm wrong but wheel spacers shouldn't affect the geometry as essentially you're only changing the offset of the wheel (bit like fitting new wheels).
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Apr 2012
    94
    Quote Originally Posted by A4_MaJiK View Post
    ur prob correct but just incase, is there a camber adjustment?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    The B7 has camber adjustment on the rear, not too sure on the front.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Pictures!!!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    not on the front
    Apr 2012
    94
    well then im ****ed cuz the camber on the front is severe, almost undriveable, maybe ive done summit wrong?
    bez101's Avatar
    Jul 2008
    8,492
    sounds like it
    iv seen them fitted a few times b4 and after tracking and there not that bad to be honest
    have you got a pic ?
    Apr 2012
    94
    also replaced both upper control arms either side while i was at it????
    Apr 2012
    94
    ill add a pic 2moro night
    Apr 2012
    94
    sorry still no pics as on 12 hour shifts and dont see daylight, had a look at car earlier and the toe is also severe, both wheels pointing in at front as well as camber in at top, ive had to park it up for now until i get to the bottom of it, any suspension experts on here? going to contact the control arm supplier and double check i was sent the correct parts, pure bummer1
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Valuable lesson, compare like for like when changing things, always check lengths, centres etc.
    Jan 2013
    Moray
    228
    You'll need to get the geometry done in order for the car to drive properly, lowering it will put it right out of tolerances. More often than not, when severely lowering a car, you will need camber top mounts to go with it. But as i have no idea what you've fitted, how low your car is or whether you've done it properly, it will be difficult to diagnose.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Quote Originally Posted by Steve220 View Post
    Quite sure he's aware of that but think camber top mounts are a bit extreme for 35mm lowering springs and B5 perches. Considering the amount of people who run identical set ups with no problems the issue is more likely to be with the replacement upper arms?
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    476
    Did you get this worked out yet Schmergal?
    Apr 2012
    94
    I did yeh, just got it back yest, upper front control arms shorter so was pulling toe and camber in, got off ebay in 1 of those kits so need to get onto them now to get replacement, just put old 1`s back in, height also raised slightly again at front so sitting perfect.
    Im liking the ride now to, apart from going over speed bumps the general ride is improved, getting a wash 2moro so will add photos, wheel spacers next, cheers for the help to all above.
    She also got debadged and cupra splitter
  1. Just Fitted Silicone T.I.P and Intake Pipes, But its not running right.
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2009, 22:38
  2. just fitted coilovers.and the wheels wont go on :(
    By petrol~head in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2009, 09:24
  3. just fitted my side skirts and gave it a good clean
    By chris_20 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2007, 21:47
  4. Just fitted a N75J Valve and ............
    By Daveiow in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2006, 14:28
  5. Just about to buy an S3 - A few questions though.
    By paulwakinshaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2005, 07:48
