EM TuningVolks Autos
    Newbos's Avatar
    Sep 2012
    115
    Help with an ecu
    Hi guys I'm after some info; I have a 2007 a4 2.0tdi 140 BRE manual and I have an ecu with serial number 03G 906 016 JD. Do any of you have the same serial number? If you have done any vagcom/vcds checks it says serial number at the top of the report. My ecu is faulty causing surging/pulsating between 1 thou and 2 thou and after that the car is perfect.
    My problem is its £800 for a new ecu
    So what I'm going to do is try find an ecu with same serial number on eBay to try that first. Hoping that all 03G 906 016 JD
    Don't have the same issue
    Simon
    Newbos's Avatar
    Sep 2012
    115
    Help with an ecu
    No one with same ecu as me?
    Newbos's Avatar
    Sep 2012
    115
    Help with an ecu
    No one? Surely there must be someone on here with same ecu
    Newbos's Avatar
    Sep 2012
    115
    Help with an ecu
    My ecu was at fault and I have a new one now and the car drives like new.
  1. help with my ecu code p0601
    By Spencer13 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th September 2012, 19:30
  2. help with reading my ecu with vag-com
    By John Spooner in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2012, 23:15
  3. Can anyone help with airbag ecu & mfsw confusion
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2011, 14:07
  4. New on here.. need help with engine ECU
    By scottyaudi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 13:22
  5. Help Please: Abs Ecu Coding and help with ecu.
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 18:02
