EM TuningAH Fabrications
    Nov 2011
    Number plate lights are out, how do I get them back on ?
    I tried to install leds for the number plate lights , they did work but not for long, (I have found many threds about this) Put new standard bulbs in and I get a bulb error and no lights. How do I get them working again, I understand that there is nothing a simple as a fuse - thats progress for you.
    Any tips
    Regards Ian
    bleedout's Avatar
    Sep 2012
    Musselburgh, Scotland
    69
    have you checked the bulb holders and contacting ok with the brass contacts in the boot lid?.
    If not try removing them and giving the contacts a clean as mine were grubby before i fitted my LED ones..
    Driver of the big Blue English Springer Spaniel bus........
    Ownded Cars:
    140 BHP A4 Avant "Spaniel Bus"
    300 BHP Focus ST3
    150 BHP Astra Sporthatch
    130 BHP Stealthed out DERV Corsa
    27,089
    Probably needs a reset tbh with vcds, but try disconnecting battery, fit bulbs then reconnect.
    You will get steering light up, but this will go after a short drive.
  1. TURNING OFF NUMBER PLATE LIGHTS WHEN DRL'S ARE ON
    By s3facelift09 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2013, 22:24
  2. How to remove rounded screw, number plate light?
    By Ben S3 8P3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2012, 21:13
  3. Number plate light out
    By zseano in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2011, 16:12
  4. Electrical problem (Number plate lights)
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2006, 14:02
  5. Anyone had problem with number plate light lens cracking/breaking?
    By jaymarwa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2005, 18:18
