Volks AutosEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
  1. #41
    Tiffy's Avatar
    Mar 2013
    Warwick
    346
    So by the looks of it the perches drop the front slightly more and gives it a much better look....
    does anyone have any pics of these perches and fitted to the acctual shock please....
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
  3. #42
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    The perch is basically the lower platform that the spring sits on. B5 perches drop down about 15mm from where the the original B7 ones sit, that 15mm translates to a 15mm drop in the ride height. Once you take the top mount and spring off you can tap them off the strut and replace with the B5 one.
    This is what I removed, B7 perch
    And the B5 perch
    Not a great picture but you can see the extra depth to it.
    I started a confirmation thread a while ago as myself and another bought perches using numbers posted previously in another thread, unfortunately they were the wrong numbers and we wasted our money. I was lucky and noticed before I stripped the car but the other guy paid someone to to change them which resulted in no change in ride height!! I'll update that thread now.
    B5 spring perch/seat confirmation
  4. #43
    Tiffy's Avatar
    Mar 2013
    Warwick
    346
    Thanks mate, thats great
    Privacy Glass
  5. #44
    May 2012
    21
    Hi Guys,
    I have a B7 S4 and read somewhere that this mod doesnt have much effect as the car is slightly lower than an sline/se already. Is this correct and therefore a waste of time for me?
    Or was this incorrect and do i need to go and buy a set of these?
    V6 Quatt's Avatar
    Feb 2008
    742
    Looks nice.
    How have the springs settled?? have you found that the car dropped a bit lower since fitting the H&R??
    How long you had the H&R on the car??
    QUOTE=ajax1976;1806616]I never actually measured mine but would guess at around 15mm.
    I have lowering springs on so two pictures are just for comparison.
    35mm H&R springs on standard perches
    35mm H&R springs with B5 perches
    [/QUOTE]
    Torque the Torque
  7. #46
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    I think I put them on around October/November. They dropped a tiny bit, 10mm(?) over a couple of weeks.
  8. #47
    Mar 2012
    North Wales
    108
    Hi all.Just an update on the RARB.....Well it went on the ramps today........WRONG PARTS Ordered The parts list I followed was on a previous thread all are correct apart from item number 8E0511327A = Mounting (rubber bush) these bushes are for fitting the 18mm diameter RARB not the 22mm dia. RS4 RARB....So AUDI are re-ordering the correct size bushes and should be arriving some time next week. I will post the correct part number when I pick them up..
  9. #48
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    Quote Originally Posted by pburv View Post
    I thought that too hence my post on the previous page #20. The part numbers were the same as the ones I removed!!
    I just went ahead and fitted them, they wouldn't sit cleanly on the bar but once the clips were fitted as I tightened them down they pulled the bushes around the bar and seated good, interesting to see how long they last tho!!
    These are the 2nd item I've bought using part numbers that have been wrong from this forum, infuriating
  10. #49
    Mar 2012
    North Wales
    108
    "Moral of the story" If you can double check part numbers with main dealer before ordering
  11. #50
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    I think I'm to blame for that, as I steered you in the direction of the wrong part numbers. Sorry about that.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
  12. #51
    Mar 2012
    North Wales
    108
    Don,t worry about it. I should have done my homework first.Will remember next time.
  13. #52
    Mar 2012
    North Wales
    108
    Well after a long wait I finally got my rarb fitted..It has made a great improvement to the handling of the car.I would recommend it to anyone who is thinking of doing this relatively cheap mod..Why Audi did not do this standard when the car first came out is beyond meps the correct part no. for the rubber bushes for this mod is *8E0 511 327 D*.If you read back to my prev. thread on this subject you will understand
  14. #53
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Great stuff; glad you got there in the end. As you say, why did Audi not set all A4s up this way from standard? Mine has a colossally heavy V6 up front, as did the B6 2.4 I had before it. Both cars benefitted hugely from the RS4 rear anti-roll bar.
  15. #54
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    101
    Don't suppose there's any reason I can't fit these cups to a B7 S4 Avant?
    2006 Sprint Blue S4 Avant - 2.5" catless DP's - Miltek Non Res cat back - BMC panel filter - JHM remap - H&R springs - Matt/Polished RS4's
  16. #55
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    No reason at all, they'll fit S4s too.
    I've got a pair in the classifieds now;-)
  17. #56
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    101
    Quote Originally Posted by ajax1976 View Post
    Can't find them, got a link?
  18. #57
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
  19. #58
    Jord_C's Avatar
    Apr 2012
    Grimsby, UK
    61
    And the B5 perch
    My cars in pieces at the minute as im in the process of doing this mod, just wondering if you use the lower rubber spring seat on the perch or just place the spring straight on the perch?
  20. #59
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    Yes I used the rubber seat although I've read of some who didn't but that was purely to get the car a tiny bit extra low. Its got to be kinder to the spring and seat with it fitted.
  21. #60
    Jord_C's Avatar
    Apr 2012
    Grimsby, UK
    61
    Good stuff, The spring seat on the perch sounds the best bet, think it will be more secure in the long run too. Thanks!
  1. My Audi A4 with 19" ADT Boston alloys and RS4 Mirror Caps fitted!
    By sduk in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 26th October 2011, 21:28
  2. RS4 rear ARB fitted
    By linners in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd April 2010, 18:56
  3. Would an RS4 ARB fit onto a B6 A4 3.0 Cab?
    By Solani in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2009, 19:15
  4. Tie bars, Coilovers and ARB fitting costs!
    By Olly P in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 19:02
  5. Clutch, Defcon stage 2 and ARBs fitted
    By Meza in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2007, 19:55
