Volks AutosEM Tuning
Results 1 to 10 of 10
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    Lack of power, juddering! any ideas?? 2.0tdi 170
    hey guys, so recently my car has started juddering again, 2.0tdi 170, remapped DPF delete/removed along those lines, anyways i was giving it blast along the motorway got to 145...ummm Kph in case of any cops wondering...
    and then it started to nicely judder after, now if i boot it from 2000-3000rpm it judders quite bad, then after 3000rpm the judder soothes out, and its just a complete lack of power,
    i've had a very similar problem before where it was juddering, but no lack of power, that turned out to be the torque limiter cutting in due to the remap not changing the settings, but i dont think its the torque limiter this time,
    i've put on a fault code reader, no faults, no warnings, checked the turbo its spot on, just wondering if anyones had the same and solved it before i start splashing out on MAF/boost sensors?
    aslo i did unplug the MAF sensor and it made no difference, but i just want to check what others have to say?
    help will be appreciated
    Camillia Well don't want to just settle for any average joe now!
    Purdy haha good point, but then again... apparently anything better doesn't exist
    Camillia No it doesn't... Hence why I'm complaining about it... Come on Purdy you can't be this stupid lol
    Purdy lol the hidden point i was saying, is surely it would be smart to stop chasing what doesnt exist.... then maybe... just maybe! it would shut all you girls up who moan about men...
    Camillia Touché
    Classic case of Girls Moaning about Boys...
    Feb 2012
    West Wales
    161
    Fuel filter?
    Mine was juddering under load and it was the fuel filter.
    Has it had the injectors changed?
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    Quote Originally Posted by eddscott View Post
    Fuel filter?
    well, it had a service 6000miles ago, oils, filters, and fuel filter, and yeah at the same time it had the injector mod done,
    it has a pretty decent lack of power aswell, currently checking all the vacume pipes on the turbo for splits, also the whole intake system for leaks, cant hear any hissing under load/boost but then again it doesnt even boost i want my turbo back!
    Camillia Touché
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    bump!
    Camillia Touché
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    My mates 170 was exactly the same, he had the fuel filter supposedly changed a couple of thousand miles before his started juddering, at the main dealer aswell. He was reluctant to get it changed again but when he finally did..........the problem was gone.
    Id definitely try it as a first port of call.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    unfortunately it wasn't the fuel filter, fitted a new one the weekend, after once again rechecking for any splits or boost leaks, and rechecked the smaller pipes from the actuator :S
    Camillia Touché
    Jun 2011
    Great Melton Norfolk
    1,356
    When you say you have put a fault code reader on the car,was it VCDS or a general code reader?
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    juat a general fault code reader from mac tools, but i asked the remappers (if thats a word) would VCDS read something that maybe my one wouldnt, he said for fault codes it shouldn't make any difference, but now i've also been told by someone else who remapps that having a DPF delete cause fault codes not to show up?? i didnt quite understand what he was on about really, but it did seem weird that no fault was shown, and it didnt revert back to standard settings when i unplugged the MAF sensor,
    Camillia Touché
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    an update for anyone who may be having similar problems, i've had the remap removed to make sure it wasnt the settings making Angelina (the A4) ill, after the map was taking off, still had the same problem go over 2.000 RPM then the judder starts, anyways after hours of racing up and down the motorway with VCDS doing a live sensor reading, and well... all sensors are happily doing there job, and just to make sure even compared the readings to another audi A4 170tdi and nothing was out of place,
    the only thing that was slightly odd was the car is slightly over boosting for standard settings (no remap) instead of 1.5 bar its at 1.6, and that the juddering starts in every gear when it builds up to 1.6 bar of boost,
    so altho it still hasnt been sorted yet, i hope that this weekend to have the exhaust off and check for any blockages that may off been caused from the DPF breaking up, as when it was removed it was only drilled to match the size of the exhaust,
    will update should i find anything and cure my baby...
    Camillia Touché
    Mar 2013
    9
    Thumbs up
    Fuel filter?
    I know this is an old thread but I was having a lot of performance issues with my one, juddering, no power over 3000 revs, like driving a 1.1 Fiesta really! Change the fuel filter and the car goes like a rocket, probably 4 x the power I had previously.
    I did clean out the EGR valve but a fuel filter is a quicker and easier job and cost £11.
    So for future readers of this thread try the fuel filter first even if you have recently had it changed. It only takes one tank of dodgy fuel to clog it up.
    Thanks eddscott for another line of diagnosis.
  1. 2.0tdi 140 Loss of power after gear change?? any ideas?
    By DCW87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2013, 15:56
  2. More Powerful Version of the 2.0TDi 170
    By DIESEL POWER in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th September 2007, 10:52
  3. power drop when cruising, any ideas??
    By spencerjoel in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2007, 13:00
  4. Losing power on 2nd???? any ideas
    By HSM in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2003, 11:58
  5. lack of power. Any idea?
    By mattstead in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 20:14
