AH FabricationsJMB Retrofits
    Feb 2013
    Poor Handling Audi A4 2.0 TDI
    Hello,
    Just joined up as was curious about an issue my car[COLOR=blue !important][COLOR=blue !important][COLOR=blue !important][/COLOR][/COLOR][/COLOR] seems to have gotten.
    Before the cold period we had the car drove and handled spot on, after the winter, the car seems to handle a lot worse and quite dangerous at times. I don't have any confidence in it. It seems very wolly and off balanced when at higher speeds.
    The car is an Audi A4 B7 (05) 2.0 TDI 140 BHP with Multi-Tronic [COLOR=blue !important][COLOR=blue !important]Gearbox[/COLOR][/COLOR].
    Does anyone know what could be causing this, it doesn't seem to shake at high speeds but has been harder to keep on a straight path.
    Many Thanks,
    May 2012
    UK
    184
    snapped spring, worn ball joint's, worn track rod end, snapped ARB drop link, could be anything but without looking and checking your only guessing
    Jan 2013
    Moray
    228
    Road salt can wear suspension components.
    Feb 2013
    Thanks guys, will get my mechanic to check these will update to see whats causing the problem this weekend just in case someone else is having similar issues.
  1. Audi A3 2.0 tdi sportback 2007 reg, poor idle issues help!
    By dawudbhai in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2014, 17:08
  2. Poor MPG Audi a4 1.9 TDI 130 BHP Sports 2004 / thermostat??!
    By Sam84 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th December 2013, 07:37
  3. Audi a4 2.0 tdi VERY poor fuel economy (20mpg) and engine starting problems.
    By audi 88 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 26th July 2011, 17:00
  4. Audi a4 2.0 tdi VERY poor fuel economy and engine starting problems.
    By audi 88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th July 2011, 10:54
  5. Audi A4 1.9 TDI 1996 Dashboard Display. Help!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 18:22
Tags for this Thread
