Volks AutosBadger5
    Feb 2011
    North Wales
    71
    Problem with central locking, electric mirrors and door iluminations
    Hi, i have two fault codes stored in the conv ECU,
    01811 voltage for door controller driver side (j386) faulty
    01812 voltage for door controller pass side faulty
    central locking, electric mirrors and the iluminations for both the front doors don't work.
    Fuses are all O.K.
    Has anyone had an issue like this?
    27,114
    I know its both doors, but check the door hinge rubbers, wires break in there.
    The fact both are down, does make you think its elsewhere, but whats 5 minutes going to hurt you checking.
    Check fuses.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    as above very common
    check the thin wires they can be broke but still look ok give them a tug
    Feb 2011
    North Wales
    71
    Thanks for the replies guys.. checked the driver door harness and found that i had a live missing. Re checked the fuse that fed this wire and found a break in the spade of the fuse and not the fuse wire. so when i looked at the fuse in the first place it looked ok.
    So replaced fuse and everything is ok
    bez101's Avatar
    Jul 2008
    8,525
    glad you got it sorted.
  1. Help with passenger side electric window and door light not working!
    By BarryM in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th September 2011, 15:22
  2. problem with central locking
    By shufti in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2007, 14:15
  3. problem with central locking
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd February 2007, 19:27
  4. problem with central locking
    By shufti in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2007, 13:35
  5. Possible problem with Going-Fast aluminium mirrors
    By gtiglasgow in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2007, 10:38
