JMB RetrofitsEM Tuning
Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
Like Tree3Likes
Thread: MPG, what do you get? TDI & TFSI?
  1. #41
    May 2012
    UK
    184
    The 3.0 is a good engine. The only issue I can think of is the inlet manifold/ runner which is common. I'm not even sure if the egr valve is a common fault or not but if I owned one I would map it out with the dpf, if it has a dpf
  3. #42
    Oct 2009
    166
    Manual 2.0 tdi 170.
    mixture of motorway with cruise control on and London traffic, 30 mile round trip.
    520 miles from a tank which is about 37mpg.
    Audi A4 Avant TDI 170 S-Line
    1992 Saab 900 T16S Convertible
  4. #43
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by S-Liner View Post
    Its looking like a 3.0 tdi next time round then!
    Great choice.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  5. #44
    Feb 2013
    Haha, I have a 3.2 Quattro tip Avant and I get 26 mpg, mostly motorways and dual carriage ways at 85, but I do drive it like I stole it half the time, particularly on slip roads and off the mark (god I love the Quattro for this)
    Glad I didn't get an oil burner now after reading this thread.
  6. #45
    GBP
    Feb 2013
    12
    i've a 2.0tdi 140ps on average my MPG is about 42.x (auto)
    from a full tank, and if i've driven a lot of mway milage and have been a sunday driver - i have got 750-800mile out of it.
    GBP
  7. #46
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    For years, I used to keep an exact check on my fuel consumption, by brimming the takn to the same cutoff point, using the same pump, and then dividing the trip mileage by the number of gallons of fuel used. I got out of the habit when i got a car with a DIS, and just relied on what the readout said. But having recently read so many posts about the Audi DIS being over-optimistic I decided to check it by doing my own calculation on my last fill up.
    I was astonished to find it was accurate to within 0.2mpg.
  8. #47
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    2.0T fsi owners in particular might be interested. I recently replaced my N80 (evap) and N75 (wastegate) due to a couple of errors I was seeing, since then my mileage has shot up to 400 miles per 60L tank fill up in my Quattro A4. If you're getting low mpg, check those fault codes!
  9. #48
    Jun 2011
    Manchester
    248
    Quote Originally Posted by OxfordRich View Post
    I recently had my N80 replaced due to intermittent idling and engine mgmt light iluminated on the dash. Although my car now behaves a lot better the MPG is rubbish. Maybe I should look at replacing this N75 too. Do you have any further info on where its located and approx price of part?
    Do you get those 400 miles on longer runs rather than town driving?
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
  10. #49
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    Sorry, I didn't mean to suggest all poor MPG would be to do with the N75, by no means, simply that in my case I had a crack in the valve. This is the wastegate control valve. I would get your car scanned for fault codes and take it from there.
    Yes, my 400 miles was on long journeys, but my 325 miles previously was also on long journeys.
  11. #50
    Oct 2012
    64
    I Get about 54mpg on little stop start country roads on my way to work and around 65mpg on motowary if i drive carefull .
    2.0tdi 140 PD
    shame they cant run on bio though would save me a fortune. Wifes a3 does and its £50 to fill up
  12. #51
    Jun 2011
    Manchester
    248
    No worries Rich, I understand and would get my car scanned first anyway before replacing parts, I have learned that the hard way all ready!
    BGB Engine Code.
  13. #52
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    I'm getting on average now, (new job & location), 330-340 miles per tank. So with a 63 litre tank, assuming 60 litres on a fill-up, 25mpg.
    Isn't terrible, but doesn't seem that great from a 3.0tdi... Maybe I should have the map checked?
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
  14. #53
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by jjmurphy21187 View Post
    Don't assume. Measure it first. Then get it checked if need be.
  15. #54
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I have stock factory map with no engine modifications. Driving is 50% motorway and 50% town with spirited driving style. Average = 33.44mpg and getting 449.5 miles per tank.
    HTH, Az.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
  1. Replies: 2
    Last Post: 16th September 2012, 12:40
  2. A3 1.6 MPG? What do you get?
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2012, 16:49
  3. A3 1.6 TDI S-Tronic MPG - what have you got?
    By mikesimbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2012, 19:15
  4. A4 3.0TDI MPG what do you get?
    By 1animal1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th October 2011, 09:16
  5. A3 1.6 lying about MPG? what do you get?
    By marcusgrant in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2011, 21:13
