Sky InsuranceAH Fabrications
Results 1 to 9 of 9
    Rueda's Avatar
    Feb 2013
    Ayrshire
    blutooth or headunit change?
    im a newbie who has just bought an 07 A4 Avant 2.0 TFSI quattro s-line tip auto . it has a symphony 6 cd with internal changer , the speakers are bose and are powered from the rear amplifier rather than the head unit as the fitter for my parrot kit found out today . i want to be able to bluetooth my iphone through the speakers. can anyone help with a solution? even if it means getting a different head unit with bluetooth which one? Thanks in advance
    26,747
    Welcome to the site.
    I have pm'd you
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    Optional bluetooth module is OEM upgrade, many many different aftermarket alternatives.
    Quick and cheap solution is something like: Play.com - Buy Venturi Mini Multi-Function Car Kit FM Transmitter online at Play.com and read reviews. Free delivery to UK and Europe!
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Jan 2013
    6
    Hi,
    I recently bought an A4 Avant and the stereo didn't work at all, it turned out that the pevious owner had used it as a money box as I found 5 coins inside when I took it out! Figured that rather than paying a costly repair bill I'd take the after market route and upgrade to add Bluetooth, DAB and iPod functionality. Looked at load of head units, both single and double DIN and opted for the Pioneer AVH-X3500DAB - a relatively new radio from late 2012 that had all of the above and more. Prices range from £330-370, depending on where you get it from and you can get facia kits and all the leads too. I used Car Audio Security, Car Audio & Security: Car Stereo, Speakers & Subwoofers, Car DVD Players, GPS and CD Changers and found them to be really helpful! Spoke to a guy called Dips who knew his stuff. The unit has inbuilt Parrot and works perfectly with my iPhone.
    Their website isn't the best but there are loads of radios that will give Bluetooth and plenty of other features too, depends what you want and how much you want to spend. Hope that helps.
    Simon
    26,747
    Quote Originally Posted by jjmurphy21187 View Post
    FM transmitters are for the best part of crap these days, so I'd be interested how this works any different as everyone I've tried is awful.
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    I'll admit that the quality isn't brilliant, but for phone calls it's more than adequate. For MP3 music it's not too bad, especially when on the motorway etc as the road noise reduces the impact of low quality sound on the ears.
    Each time I want to use the phone on the move, I just plug it in, turn my phones bluetooth on, switch to the FM preset and you're done. The transmitter I have also works using the TP signal, so if you're connected etc and have traffic reports enabled the HU automatically swithces to the FM frequency of the transmitter when you receive an incomming call.
    Think mine was £40 ish. But no wiring, and I've had it in my past 2 cars as well. Works ok with the roof down too surprisingly...
    Rueda's Avatar
    Feb 2013
    Ayrshire
    i am just going to use my tom tom for the phone calls and make up mp3 discs for music purposes its the cheaper option compared to upgrading the system.it was always going to be a ball ache to remedy becasuse everything runs off the a mk p in the rear of the car Thanks for all the comments
    26,747
    Yes but what if a conflicting station is on the same frequency, do you not get interference?
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    It's never happened to me? You just select a frequency which is right at the end of the scale (107.9). Plus you're in such close proximity to the antenna the signal from the transmitter is stronger than any radio waves being broadcast. No doubt if you buy one of the cheapo £5 transmitters from eBay the signal might be weaker and make this problem more prominant, but mine had been fine
  1. Changing Headunit.
    By Niko in forum In-Car Entertainment
    Last Post: 24th October 2007, 11:25
  2. Fasia replacement changing radio / headunit 2002 S3
    By davebirl in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2006, 17:10
  3. Fasia replacement changing radio / headunit 2002 S3
    By davebirl in forum In-Car Entertainment
    Last Post: 14th December 2006, 17:19
  4. Changing the Headunit on a Bose system
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2005, 15:28
  5. changing cd headunit
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2004, 08:41
