Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Jun 2009
    15
    Revo couldn't map to stage 2+ due to low fuel pressure?
    Hi,
    Can someone please help, I have a a4 b7 2.0tfsi with an autotech hpfp, I took my car to Revo hq in Daventry,
    they mapped the car and took it out to log data and the fuel pressure was around 110 and they said it should be around 130,
    iv stripped the pump down to check the internals and i cant see any wear, there was a small circle imprinted on the cam follower
    could this be an issue? or does anyone have any suggestions on what the problem could be?
    Nick.
    Mar 2011
    112
    110 bar is fine for standard hpfp, Audi spec is and i quote 'approx 50 bar at idling speed and approx 110 bar in certain parts of operating range' at coolant temp of approx 85 deg C. Do you have a spec from autotech and if so what do they quote?
    Jun 2009
    15
    Quote Originally Posted by Custardsucker View Post
    Hi, so iv taken it out with a friend who ran a log and its now running 130 fuel rail pressure which i think is good? its the same as his s3 and he also has a autotech fuel pump. i will try get it mapped again tomorrow.
    thanks for your help.
    Jan 2013
    Moray
    228
    130bar?! Is that a writing error or do you mean 130psi?
    Jun 2009
    15
    Quote Originally Posted by Steve220 View Post
    it was 50 bar idle and 130 bar under acceleration, does that sound right or is there a problem?
    its not misfiring and it seems smooth.
    Thanks.
    Jan 2013
    Moray
    228
    I'm just amazed at the pressure to get fuel into the cylinder. Try one of these:
    APR 2.0T FSI High Pressure Fuel Pump
    Jun 2009
    15
    I find it hard to believe also! I'm a plumber and we work in bars but in single figures!
    I will go with the apr if this isn't working or i'll get one if it fails.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    110 bar is standard. If it is 130 bar it has a map on it. HPFP's can be very unreliable.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. Revo Select Plus recommended settings stage 1
    By S321BAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2011, 22:47
  2. Revo Select switch & prep for Stage 2+
    By S3RYE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2010, 11:59
  3. APR Vs REVO - Audi S3 2.0TFSI Stage 1!
    By AwesomeMike in forum Awesome GTI
    Last Post: 21st October 2010, 12:59
  4. is a 4 bar fuel pressure regulator needed for a revo stag 2 remap
    By westu_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2010, 08:20
  5. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
