Sky InsuranceBadger5
Results 1 to 8 of 8
    alpesh26's Avatar
    Mar 2011
    271
    Strange tyre wear
    I seem to be getting weird tyre wear on my A4. The front left tyre has worn more (across the whole tyre - maybe a touch more on the outside) than the front right.
    The front right has about 6mm left the front left has about 4mm left.
    The front right had a leaking valve but I got this fixed 2-3 weeks ago and it's been fine since. Tyre pressures are at 33 psi all round.
    The car is on oem SE suspension (covered 92k), the original 16" wheels and Michelin Primacy HP tyres all round. All 4 tyres were fitted at the same time.
    Any pointers to what could be causing this or is it nothing to worry about?
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Sep 2012
    223
    Get your tracking realigned ans should tell you if it's out?
    27,114
    As above.
    AudiB7Jay's Avatar
    Nov 2012
    374
    Yeah I agree as above, if you have vibration through the wheel too have them balanced as that will probably cause some sort of uneven wear.
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    Sounds like too much toe in on front left. Or you love throwing it round roundabouts!!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    alpesh26's Avatar
    Mar 2011
    271
    Quote Originally Posted by Big Al View Post
    Yeah it does get thrown around roundabouts which would explain the slight wear on the outside. I forgot that its got it's MOT on friday so i'll get the bushes etc checked then. Will get it booked in for 4 wheel alignment too. Would an RS4 RARB stop some of the wear on the outside of the tyres when cornering? Being an SE the cornering is a bit 'squidgy'
    Feb 2008
    281
    Tell the misses or boyfriend to lose weight
    Feb 2008
    281
    and dont say i said...lol
  1. Strange uneven tyre wear...
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd August 2013, 02:02
  2. Another broken rear spring.....and strange tyre wear.
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 11:43
  3. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  4. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
