Sky InsuranceEM Tuning
    Mar 2012
    Essex
    115
    Opening up the fuse box in the engine bay - help!
    I had a quick look at opening up the fuse box in the engine bay (by the battery), and there appears to be a screw down the back, very hard to get to. Is there a guide to help open it up? Or anyone got any ideas? I even tried to take off the windscreen wiper so I could remove the plastic underneath but the wiper bolt was attached solidly - no movement in that bolt!
    madstaff's Avatar
    Apr 2012
    73
    Assuming you mean the fuse box at the rear of the engine bay on the left, I used a torx bit, just the actual bit itself, turning it with a spanner and you can undo it that way.
    A bit fiddly but can be done.
    Audi A4 Avant 2.0TDi S-Line Special Edition
    Mar 2012
    Essex
    115
    Cheers for that. Do I need to remove the plastic bit that runs along under the wipers? Seems to be in the way, or will the lid come off with it in place?
    madstaff's Avatar
    Apr 2012
    73
    The lid can be removed without removing anything else - just, as its a tight squeeze!!
    Mar 2012
    Essex
    115
    nice one, i'll give it a go at the weekend!
  1. Are all the auto boxes in the 3.2 / 2.0T etc A3's all DSG / S-Tronic?
    By its_neil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd July 2011, 22:25
  2. Where are the fuse boxes in an A3 2.0 TDI
    By lanky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th June 2011, 12:54
  3. Still on the look out for a engine bay cover
    By s3 man in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2010, 18:38
  4. Where is the fuse box in my A3?
    By sharma in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2008, 18:01
  5. air sensors in the air box?
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:57
