Sky InsuranceBadger5
Results 1 to 7 of 7
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    Anyone know how to remove the driver side door lock
    I've nearly managed to get my rattling door mechanism out but one part escapes me. There is a metal wire/rod that attaches the door latch to the inside of the main door handle. It is held in place by a white plastic collar and at the bottom a yellow and black clip. It's a tight squeeze in there and I've tried to unclip the rod so I can pull the mechanism out with no joy.
    Anyone done this or know how exactly the metal rod is held in place?
    Anyone able to tell me the part number for the 8mm spline screws holding the latch in place as one of my needs replacing.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    27,029
    I sounds like same as the 8P, the clip just folds over the bar & stays closed against the rod, you just need to open the yellow clip & the rod usually just pops out & then can be manipulated/twisted out of the collar.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    This is the mechanism, the ones I could find on ebay all seem attached with that clip. The rod has a screw thread inthis black clip so assume it screws in. Presumably the top comes out of the door handle white clip but can't figure out how. Grrrr.
    Nathan
    27,029
    Show me a pic of your mechanism with clip, so can see if its the same then can advise.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    Just had a fight with my gf's camera, hopefully this is clear:
    Nathan
    27,029
    Yeap, same one, ok so lets say 3rd pic, you need to iirc pull the yellow clip on the left to the side, which then releases the black wrap over part, make sure you pull carefully the black part over to the right & this actually locates on the yellow part on the right to keep it there, then the bar will be free to pull forward & out.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    Cheers. Will have a play when I get a moment
    Nathan
  1. Anyone know how to remove the glove box lid/door
    By chris_marshall in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2011, 18:57
  2. Anyone know how to remove the number plate fitment?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2011, 21:19
  3. Anyone know how to remove the vent rings?
    By audiv6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2010, 18:54
  4. Replies: 0
    Last Post: 4th August 2005, 22:47
  5. does anyone know how to replace the Lambda sensor?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2005, 23:26
