Chris NottBadger5
Results 1 to 7 of 7
    Danny-boy's Avatar
    Jan 2013
    477
    CANBUS Bulb Warning
    Hi all,
    With regard to the Canbus bulb failure warning, I'm interested to know how this works.
    Does the system look for a certain resistance, or does it look for a certain "minimum" resistance?
    I plan to install LED sidelight bulbs, and also tap some DRL's into the circuit. I'll measure the resistance of the original bulb, and the LED's and get a resistor as close to the difference as possible.
    How accurate do I need to be? I don't want to be too far over the resistance of the standard bulb due to heat, but how accurate do I need to be?
    That is of course assuming it's only resistance that is monitored.
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    346
    T8ups does some led sidelights with built in halogen bulbs so no errors come up, you could then get them activated as DRL's. check out his members page pal.
    CREE 501 Sidelight
    A4 Avant B7
    LED Rear Lights - Mesh Grill - SLC Splittler - Ice White Fogs - Tints - Devil Eyes - Ambient lighting - LED interior
    Danny-boy's Avatar
    Jan 2013
    477
    CANBUS Bulb Warning
    Thanks mate, but like I said, I'm wiring DRL's off the sidelight circuit as well.
    Just want to know if I need an "exact" resistance or a "minimum" resistance.
    Dan
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    I always though it worked on current draw? If a bulb blows there is no current due to open circuit, if an LED bulbs is used there is also no current due to the minimal power required for the LED to illuminate. Therefore an additional resistor draws the correct power it removed the dash error.
    Overall I would think that you'd need to get it roughly correct, but given the tiny amount of power that LEDs actually use just use a 5w load resistor and this should get rid of any errors.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    NOZ
    NOZ's Avatar
    Feb 2013
    Dundee
    192
    Quote Originally Posted by jjmurphy21187 View Post
    Just buy canbus error free led bulbs i have and they work fine i have just got the same but for the indicators but now need to purchase one of these
    3 Pin Electronic LED Flasher Relay Fix Turn Signal
    Brand new and high quality
    3 pins electronic LED flasher relay (CF13JL02)
    It can replace the normal thermal flasher
    It can solve the turn signal problems such as hyper flashing, no flashing or stop bulbs blowing
    Plug and play
    12V, 0.02-20A
    Plug and play
    12V, 0.02-20A
    hopefully this will sort out the rapid flashing
    Jun 2011
    Wellingborough
    1,174
    Danny Boy.
    i will sell you one of these - Canbus sidelight loom. Get rid of that Error!
    but them into 2 so you have 1 on each side, wire them to the new circuit you make and hide it away with a 501 halogen bulb in there, error wont appear as the car will see a halogen connected so no errors. jobs a good un.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Danny-boy's Avatar
    Jan 2013
    477
    CANBUS Bulb Warning
    Cheers mate, but it seems I was worrying for nothing.
    My car does not monitor bulbs by the looks of things.
    Dan
  1. 'Blown Bulb' warning still on after replacing H1 bulb
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 15:07
  2. Washer and bulb warning lights
    By sos_85 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2008, 20:49
  3. Bulb Warning after HID install
    By Dave_Bayern in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 22:35
  4. Removed rear spoiler... BULB warning comes on :(
    By ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2006, 15:15
  5. Light bulb warning ????
    By godwine in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 01:21
