Chris NottBadger5
Results 1 to 8 of 8
    Jan 2011
    224
    tiptronic gbox questions
    Hi!
    After writing off my a3 2.0tfsi s line, I am thinking of purchasing this
    Audi A4 3.0 TDi TDV Quattro S Line 4dr Tip Auto Diesel 2006
    My question is, what is the tiptronic like? I have has dsg/s-tronic in my last 2 cars.
    Also does the a4 have paddle shifters like the DSG does? I am hearing mixed answers, some saying they do, others saying they dont etc.
    Many thanks
    2008 A3 1.8t FSI Sportback S-Line - Avus Silver - Full spec.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    I've never driven a DSG, so can't offer a comparison, but I can tell you that the 3.0TDi in combination with the traditional auto gearbox is just marvellous. If you're feeling lazy, leave it in D and let the box do all the work. If you want some extra go, but are still feeling lazy, pop it into Sport mode and it'll change up later and change down sooner. If you want to do all your own gear changes, put it in Tiptronic mode. What could be simpler?
    Whichever mode you're in, changes are quick, responsive and smooth, making the car an absolute joy, and very easy to drive very quickly.
    As far as paddle changes are concerned, they were an optional extra - what did you expect, this is Audi after all! So you might have to hunt around to find one.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    27,113
    Yeah lovely engine tbh & dsg is great.
    V6 Quatt's Avatar
    Feb 2008
    783
    Tiptronic box works well with the 3.0TDI
    As Jpd said above. Effortless with 3 driving modes I'm sure you won't be disappointed. Drive it a and see for yourself.
    Torque the Torque
    V6 Quatt's Avatar
    Feb 2008
    783
    I just checked the spec and its fully loaded. It may be a non DPF which will be a bonus.
    Let us know how you get on
    Torque the Torque
    Jan 2011
    224
    If it doesnt have paddles, can I just swap the steering wheel for one that does, would it require vag com, or does it not work like that?
    Also, is it a reliable gearbox?
    And does it need cambelt change at that mileage?
    27,113
    It may be coded already, so you'd have to test, but more than likely it would need coding for paddles, also its got the correct steering cu etc, so saves a vast amount for these.
    If you need to installed etc let me know
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Quote Originally Posted by thesmileyone View Post
    The ZF auto boxes are renowned for reliability. That doesn't mean they never go wrong, but the point is they have a reputation for being strong. Also, I'm pretty certain 3.0TDi has chain-driven camshafts, so no cambelt change needed.
  1. Newbie with some questions about changing the oil in multitronic gbox
    By Seville in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2011, 22:04
  2. tiptronic question
    By hilly in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th October 2009, 17:53
  3. The Big Question - War
    By Moresauce in forum General Chat
    Last Post: 28th February 2003, 16:10
  4. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
