Monster MotorsportChris Nott
Results 1 to 24 of 24
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    No remap said I was burning oil
    Hi guys I just returned from the garage where my car a Audi a4 tdi 170 it was supposed to get a dpf deleted and remap but he said he wouldn't do this as my car was burning oil and had erratic injector corrections he said I was burning oil due to the white smoke coming from back as far as I'm aware my car dose this on startup but once warm it's doesn't smoke anymore and I have Owned the car for 9 months and never had to top up the oil even checking every week if I was burning oil iw old need to top up surely as for the injectors these where replaced by Audi at the last service under the recall any ideas how I can check if I'm burning oil with out a hefty garage bill many thanks Chris
    Alex_Dubz's Avatar
    Dec 2012
    Bucharest, Romania
    23
    Are you sure its white smoke? Cause oil smoke should be blue. White smoke means coolant in the exhaust.
    AudiB7Jay's Avatar
    Nov 2012
    374
    I'd agree oil burns blue smoke
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Blue when cold once warmed up smoke has gone but not requiring to top up oil it stays the same level
    Nov 2012
    York
    39
    Interested in following this, i sometimes have a light plume of bluey grey smoke if i put my foot down but checking the oil it never seems to go down at all.
    Its the 170 with dpf, does anybody else have this at all?
    Im not sure whether it just does it after not putting my foot down for a while, i don't think it does it constantly when accelerating.
    I do sometimes feel the slight cough when the dpf regens, but i don't think the smoke is related to this?
    Dec 2006
    N.Ireland
    369
    wouldnt be the injectors weeping?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    take it to a diff garage for a map
    if your not topping up then all should be good.
    but audi do quote upto 1tr per 1000 miles
    brasiliangringo's Avatar
    Mar 2010
    544
    Horse ****, Tdis always black smoke under inital 'lead foot' but as above, white is not oil..
    Nov 2012
    York
    39
    Is this the same with a dpf? I thought they were supposed to stop that?
    If thats the case ill stop worrying
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    So you think I shouldn't worry as he seemed to think if he remapped it would blow up or something he also recommend that did a compression test as he said it was piston ring related I have looked at exhaust as well and there is no oily residue on the pipes and its a brand new stainless system so if I was burning oil there should be signs of oil residue and power doesn't seem affected pull like day one I purchased it
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Ok booked in with http://www.omg-performance.co.uk/contact.html on Wednesday lets see what happens fingers crossed
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,088
    In Reading? Keep us posted, be interested to see how you get on.
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Ok update I decided to clean the egr valve replaced all gaskets and seals and after removing the intercooler pipe I found oil in it this bad I know after starting it up I got plumes of blue smoke from cold but warm no smoke again so is this a symptom of oil seals on the turbo or some other seal or just from where the gunk from the inlet got into the combustion chamber ideas please
    Nottingham
    72
    Some oil in the cooler pipes is quite normal
    Volume is nothing without control
    May 2012
    UK
    187
    Check the turbo. remove the air filter and remove the pipe that goes from the MAF to the Turbo. you should be able to feel if there is play on the turbo. also get your phone down there and take a picture of the turbines. there should be virtually no play on the turbo if its not knackard.
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Ok thanks will check this in the morning and report back I hope it's not the turbo I know that's big bucks to fix
    Jun 2010
    South Wales
    69
    Sounds like the garage has sound advice. They could have remapped it and said nothing. Then your engine could have gone bang. A remap will soon find any weakness. Have your turbo checked before you have the remap.
    Jan 2013
    Moray
    228
    How did he know you were burning oil? Did he have an exhaust probe on it? White smoke could just be condensation burning off in the exhaust itself. Blue smoke on initial start up then clearing up could be stem seals leaking. If a turbo seal is leaking, it will burn oil all the time when the oil pressure rises. It could be the garage has no real idea. Too many variables.
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    Ok I see that the turbo looks fine can't see any play I read somewhere that the seal when cold weep oil and when they warmup they stop any oil on the turbo seals or as Steve220 said maybe the stem seal where can I locate these to check as this seems to be the issue once staring cold I get the blue smoke once I drive off and after 5 mins its gone but I am hoping omg performance might be able to advise me on Wednesday as they promise a diagnostic check while performing the remap not just pluging in the car but performing a manual inspection.
    Jan 2013
    Moray
    228
    Thats how i'd expect an inspection to be done anyway. Too many damn electrics in modern cars, nothing wrong with going back to basics. Stem seals are hard to diagnose on sight as its all internal engine.
    Apr 2012
    43
    My 170 was the exact same. It was the oil seal in the turbo and the intercooler had gone too. Also had to replace the tandem pump and diesel pump in the boot. This cured all my problems ,like the ones you have. Got the remap dpf and egr delete. Like a new car now.
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    sorry to ask but how much was the repair bill for the turbo seal intercooler and etc just kneed to know to justify the cost if you dont mind pm me and did audi carry out the work or an independent garage
    Beeblebrox's Avatar
    Dec 2012
    Langley Berkshire
    89
    So omg did my dpf egr valve delete plus remapping great job the guys where friendly and knew what they where doing they checked my turbo and for other signs of leakage but alas none to be found.
    I left David and his mechanic mario to the job while I went into town came to find the work done and they where putting the car back together.
    David from omg performance took me out for a test drive and the difference was astonishing after we came back he plugged the car back in to check he mass air flow and as I was getting a acrid smell the oxygen sensor which seemed fine the car runs like a dream I even get a bit of turbo whistle now but the smell he said he couldn't do anything about just told me to keep an eye on the sensor as this usually is the cause of such a smell but over all they did a brilliant job and I would recommend them
    Apr 2012
    43
    Good stuff. The car drives far better with all those extras off it. Lol. Cost me £700 from tuning company to do. Car runs great now
  1. 1.9tdi A3 burning oil
    By rws in forum Diesel forum
    Last Post: 10th December 2007, 12:23
  2. audi 100 starting to burn oil
    By imported_avcraven in forum Classic Audi Forum
    Last Post: 24th April 2006, 22:48
  3. Who said turbo needs Engine Oil?
    By godwine in forum General Chat
    Last Post: 6th November 2005, 00:02
  4. MOVED: burning oil
    By CaliAudiA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th January 2005, 04:27
  5. Burning oil smell
    By stebed in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2004, 21:17
