Chris NottMonster Motorsport
Results 1 to 8 of 8
    Danny-boy's Avatar
    Jan 2013
    477
    A4 B7 First Aid Kit
    Hi all,
    I heard there is supposed to be a first aid kit in the rear armrest, but mine is empty.
    Somebody mentioned the kit is specific as it needs to be stepped, but my one is a constant depth across the rectangular recess.
    Do I have a different armrest? Is there a different kit that fits?
    Dan
    AudiB7Jay's Avatar
    Nov 2012
    374
    This is a new one to me tbh i have the 57 plate a4 but i dont even have a first aid kit in my car? is this a standard issue with audis?
    Dec 2011
    Glasgow
    195
    A4 B7 First Aid Kit
    Mine didnt come with a first aid kit either. I brought a first aid kit from boots it's a canvas bag like linked
    It slides in with no problem you just need to check and measure the size to check it will fit.
    I'm sure if you buy the Audi first aid bag it will be silly money for something you don't see or use often
    http://m.boots.com/mt/www.boots.com/...d-Kit_1258539/
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Mar 2011
    S E Kent
    238
    I popped one of these in my cab rear arm rest
    Autocare First Aid Kit | Safety Equipment | ASDA direct
    2006 A4 cab
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Quote Originally Posted by Gazthesparky View Post
    Spot on, Gaz. This really in one occasion where OEM is not necessary.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    g00se's Avatar
    Nov 2010
    Reading
    265
    £28 for the TT version - mental!!!!
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    Molnboman's Avatar
    First aid kit?......if it's blb engine that would be an new oil pump! :-) Sorry.....my question would be why?.....I have one these bad boys...it has velcro and sticks nicely to the back inside wheel arch covers. Första hjälpenkudde, de luxe - Biltema
    MM
  1. S3 First Aid Kit - Who's Got One??
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2014, 09:43
  2. First Aid Kit
    By mhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2013, 19:22
  3. First Aid Kits
    By David in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 22:21
  4. first aid kit location...
    By evilscotsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th July 2008, 15:23
  5. First Aid Kit - Where Is It?
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2007, 17:55
