EM TuningMonster Motorsport
Results 1 to 7 of 7
    May 2012
    21
    B7 S4 Parott Install
    After some help/advice. Just bought an mki9000 parott kit to put in my 05 S4 with RNSE. Some things i read say it is going to need the quadlock adapter, others say it will be ISO. I realise there may be no way to definitely know before taking it out but just wondered what its likely to be so I can have the lead ready if necessary.
    Is there any other advice people can offer with regards to the removal and then subsequent fitting of the parott kit?
    Thanks in advance.
    Will
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    The RNS-E has a Quadlock, ISO will be useless to you.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    27,114
    As PD says, quadlock mate, if it doesnt come with quadlock adapter, then you will need some 000979009E or EA repair wires to connect the wires to rns, solder the power wires -/+ to existing, I dont use crimps as they're rubbish.
    Why not fit the audi system mate, integrates well with rns-e, if it takes your fancy, PM me for a price
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    +1
    No nasty extra boxes hanging off the dash, just a clean OE look that works great.
    May 2012
    21
    I would of loved the audi set up but everything i read said about how expensive it works out!
    Thanks for your help guys
    27,114
    I wouldnt call the oem integration that expensive tbh mate, not as expensive as filling up an S4 everyday like I used too lol, PM if you'd like a price for the oem BT
    2,175
    If you what to DIY there are kits on ebay AUDI Bluetooth KIT Plug&Play A4 A3 A6 TT new 8P0862335 | eBay which are not a bad price, but you would need someone with VCDS to code the RNS-E & Bluetooth for you. Have a look at the VCDS map to see if there is someone local to you VCDS (formerly VAG-COM) forum
  1. getting and installing sat nav
    By sash in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2003, 11:45
  2. Installing a subwoofer in a 2000 a4
    By anastasia248 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2003, 00:49
  3. Help Installing Kenwood music Keg cable
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 07:35
  4. A4 AVANT INSTALL
    By AndyC in forum In-Car Entertainment
    Last Post: 29th July 2003, 13:33
  5. big headache on a3 ice install
    By dsiewuk in forum In-Car Entertainment
    Last Post: 28th June 2003, 17:26
