EM TuningJMB Retrofits
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By jjmurphy21187
  • 1 Post By jdp1962
Thread: 3.0TDI S-Line 18” Tyre and Wheel options.
    Dec 2011
    11
    The tyres on my 3.0TDI S-Line are coming up for replacement. I’ve been searching the forums and understand that one of the best options is (IMO) to replace them with vredestein ultrac sessantas. However I’ve started to become annoyed with the harshness of the S-Line ride on 18” wheels with low(ish) profile tyres – in particular pot hole strewn back roads. I’m guessing that replacing the wheels with smaller 17” wheels and higher profile tyres will improve the ride. Questions then – I know the SE 3.0TDI came with 17” wheels – can I simply fit these or will it mess up the handling? – i.e. do I need to change anything else? In addition could I fit 17” wheels fitted with 225 section tyres rather than the standard 235 OEM tyres
    Thoughts appreciated
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    Fitting narrower tyres will fit, but why would you want to? Get some OEM 17" A4 alloys and get a higher profile to help improve ride comfort, but I'd keep the tyre width the same.
    As for improving the ride quality, new springs will probably make as much different as new tyres (if not more) so consider changing them as this will give better handling, improved comfort and a better stance. Standard shocks can be used with most aftermarket springs (30mm, 40mm, 45mm etc) and the s-line springs as standard have a reputation for giving pretty poor ride quality ('crashy' s the term used most often).
    I upgraded to 19" and went from a 40 profile to a 35, also changed the springs to H&R -30mm at the same time and 80% of the time the ride quality has improved. There is the odd occasion where a bumpy side road would have felt more cushy on 40 profile tyres, but if I had the standard 18" alloys I'm sure it would be infinitely more comfortable than the standard s-line springs.
    Also the Vreds are excellent tyres, can't recommend them highly enough!
    DrAlf likes this.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    I have a 3.0TDi SE which came on 17" wheels at the outset. The standard tyres were 235/45/17s. I also, for a short time, ran it on a spare set of wheels, that happened to be fitted with 225/45/17s. So either will fit, and provided you use good quality tyres, there will be no problems with the handling.
    However, I don't think changing the tyres will solve your problem. The harshness of the S-Line ride is not down to the tyres, it's down to the springs and shock absorbers. My recommendation would be to keep your 18" wheels and tyres, and replace the spring and shock absorbers. Speak to Damian at DPM Performance (he is a forum member) about a suitable kit for your car.
    DrAlf likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    D@mn you and your speed-typing, jjm!
    Dec 2011
    11
    Excellent - thanks for the info chaps. I'll get a set of Vreds on order and will start to look into spring options. Ta
    mehtaman's Avatar
    Feb 2012
    Wembley, Middlesex
    63
    Quote Originally Posted by DrAlf View Post
    I just fitted a set to Vreds to my car on saturday (235/40/18), the 30mile return journey was much improved... I still need to see what PSI the fitter installed them with and adjust if required.
    Not sure if you have had a read of this post... Vredestein bargain
    The 3.0TDi guys are running around 40-46PSI, not sure if that will help the ride quality much.
    | Audi A4/B7 2007 | 2.0TDi | S-Line | RNS-E | 18" S-Line Alloys |
    | Modifications | Pure Highway 300Di DAB | BlueFin Remap |
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Quote Originally Posted by mehtaman View Post
    Mine run at 38psi.
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    I think the 3.0tdi must have higher psi ratings due to the heavier kerb weight... will check when I get in later but I compromise and run 40 normally... (38min & 44max from memory?)
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Run mine at 38-39 aswel
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    quattronly
    Jun 2011
    SW Scotland
    105
    I found that changing to 245/40 R 18 gave a less harsh ride to my S-line on account of the additional 4mm ride height on top of a full complement of tread - so the best part of 10mm over all.
    Dec 2011
    11
    Quote Originally Posted by Jeeves View Post
    Interesting. Thanks for the info. Will 235 tyres fit the standard 18" rims or do I need to change the wheels as well?
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    I think 235 IS the width of the standard tyres on 18" s-line alloys...
    Dec 2011
    11
    Quote Originally Posted by jjmurphy21187 View Post
    Correct - sorry my typo - I meant will 245 section tyres fit on the standard S-Line rims?
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    Would've thought they would fit, in the same way 225 will fit but give a slight stretch, but the outer walls of the tyre would be angled outwards slightly
  1. Spacers / Tyres and Wheel Bolts
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2012, 11:33
  2. Cheap(ish) Audi winter tyres and wheels package
    By SebRogers in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th September 2011, 17:19
  3. Snow Tyres and Wheels
    By machtzu in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th January 2010, 22:52
  4. A4 2.0tdi s line. Steering wheel vibration
    By yipadee in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st November 2008, 13:19
  5. tyre change and wheel alignment HELP!
    By stevehart in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2006, 11:23
