Monster MotorsportVolks Autos
    Jul 2011
    14
    Emission Control Light = time to kill yourself!
    Hi Guys,
    My Wife was driving my Audi A4 2.0TFSI 2006 and the dreaded Emission Control Light came on the dashboard (it stays on and does not flash btw). I then decided it was time to take it to a VW/Audi specialist and after plugging in his VAG-COM and checking the codes he told me it was the breather valve (seemed pretty sure). I decided before I would book it in for repair and pay him a small fortune, this might be something I could do myself.
    All the symptoms and fault codes pointed towards the PCV valve, so I ordered the PCV (part number 06F129101N) and a new gasket from Audi.
    I asked a semi-retired mechanic friend of mine to change this for me and thought that would crack the problem after clearing the codes but to my despair it came back on the next day and now stays on!
    I can't say I have noticed any problems when driving the car but it does vibrate a little when idle but I think this is normal... I have also noticed over a period of 3 months it does shoot forward a little (hardly noticeable) when pulling out of my drive at slow speed but not sure if this is related (could be wrong..)
    The codes that the VAG-COM displayed are shown below:
    1/3 ID:2187 -01
    08583
    System too rich off idle, Bank 1
    System too lean at idle speed
    2/3 ID:2261 - 01
    Recirculating valve for turbocharger -
    N249 mechanical malfunction
    short circuit to another valve
    3/3 I: 0507 - 01
    01287
    Idling speed regulation RPM above specified value
    value of resistance too small
    I am completely lost now and close to pulling out all my hair so hopefully someone on this forum might be able to help me having experienced something similar or know more than I do (which isn't much!) and perhaps have a solution to this problem and locate the actual issue?
    I have read it could be the 02 sensor but then again various posts and forum say it could be any number of things because from what my friend said Check Engine Lights are a dealers/mechanics dream. It can end up costing hundreds in labour to locate the problem and then you drive away and it is still not fixed which is something I obviously want to avoid.
    Any help would be greatly appreciated, thank you in advance!
    Steve
    Jun 2011
    Manchester
    227
    Could be the N80 valve. I have replied in another thread where you asked if I still had the same issue.
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    Have you tried cleaning your EGR valve?
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Jul 2011
    14
    No I haven't yet but I will certainly give it a go. Thanks
    Mar 2011
    112
    Not 100% sure, but don't think 2.0T FSi has EGR.
  1. Audi A3 8p emission control light, Surrey - VAG-com help?
    By Greenmunkey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2010, 03:01
  2. help.. Emission control light has come on..
    By andyb_88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2009, 11:23
  3. Emission control light on
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2008, 18:16
  4. Emission control light on - expensive quote from Audi to diagnose
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2008, 14:40
  5. emissions control light on
    By GARTHY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th December 2007, 12:06
