EM TuningChris Nott
    Jan 2013
    30
    Now I have my turbo out with mr muscle
    Now I have my turbo out on my 2005 tdi I thought I would give it a clean with mr muscle. I know with the innotec kit you get a stage 2 clean out. What could I use in replacement that would not cause the turbo any harm?
    27,114
    Just clean up the internals with a dremel with wire wheel on end, works brilliantly.
    Jan 2013
    30
    Is that after the mr muscle mate? Or should I not bother with it?
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Re: Now I have my turbo out with mr muscle
    If you have the turbo out and got easy access I'd consider just using manual methods as NHN said. Mr muscle is handy for when it's in place as it works well due to expanding, but you know you're not going to do any harm with manual methods and you'll probably get a better result.
    Jan 2013
    30
    Thanks guys, much appreciated. I might be back if I get stuck :-)
    Also is there anyway to test my n75 valve and solenoid? As I believe the actuator diaphragm has gone. That the reason for removal.
  1. Changed to BT Infinity with Home Hub3 - Now I have wireless network issues
    By jdp1962 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 29th October 2012, 16:38
  2. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  3. Out with the old,in with the new !!
    By neil20vt in forum The Welcome Section
    Last Post: 22nd June 2007, 08:24
  4. OUt with the old in with the new
    By killbill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2007, 19:12
  5. can someone help me out with a part number please
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2006, 20:22
