JMB RetrofitsAH Fabrications
    Jan 2012
    100
    anyone know if 18" et29s will fit
    i have been offered a set of a5 5 spoke alloys with 245/40/18 tyres and the offset is et29?i know there is rubbing with 19" et29 but not sure if there would be any difference being 18".dont know if they would stick out 2 much.i have standard s line springs.any info would be appreciated
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    With that offset you probably wouldn't get any rubbing on the inside arch, it would all be on the outside if there was any.
    Standard A4 s-line wheels are 18", ET43 235/40/18. So you're effectively moving the outter edge of the wheel out by 14mm. You can measure the difference and see what the poke would be. Another way to reduce the rubbing out the arches is to use slightly thinner tyres so the tyre wall is angled and thus reduces the risk of rubbing.
    If you have 19" ET29 you'd probably run 245/35 not 245/40, so the rolling diameter will be (near as damn it) the same. Therefor if there is no stretch on the tyres the chances of rubbing with 18" would be the same as 19".
    That's my understanding of it at least, other people run far greater offsets than me so no doubt they can chime in and offer their 2p. Do you regularly have a full load in the car? If 90% of the time it's just yourself you can probably live with occasional rubbing.
    If you're into your modding, changing the s-line springs is something which is WELL worth doing as the ride can be greatly improved plus it decreases the arch gap. If this isn't for you then it's irrelevant, however if it's something you might do down the road you might want to think about using a 'safer' offset just in case.
    Remember: You can always decrease your offset (lower ET) with spacers, but you can't increase it (higher ET) without changing you wheels...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    One thing which would be useful to know, what width are the rims in question?
    Jan 2012
    100
    Thanks for the reply.its usually 2 adults n 2 small children in the car.the wheels are 8.5 j and are from a new a5.i know they are pushing it and are probably just to wide but i thought it was worth asking just incase anyone could tell for sure if it would rub or not
  1. does anyone know would 18" S5 ALLOYS WHEELS fit A4 2008
    By lochandubh07 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2011, 20:27
  2. does anyone know would 18" S5 ALLOYS WHEELS fit A4 2008
    By lochandubh07 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th June 2011, 20:21
  3. Anyone know if these wheel caps will fit?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 00:08
  4. Anyone know part a connector that will fit over this 893 971 632?
    By emeraldA3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2010, 23:38
  5. Anyone know if these will fit ???
    By Jonny0069 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2010, 18:49
