Volks AutosJMB Retrofits
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    2.0 T fault code
    any ideas cam follower ok and changed fuel filter changed
    18725/P2293/008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Power Loss
    Possible Causes
    • Fuel Pressure too Low
    • Intake Camshaft Failure
    Possible Solutions
    • Check Measuring Values for Fuel Pressure
    • Check for bent/squeezed Fuel Lines
    • Check Fuel Pressure System for Leaks
    • Check Fuel Filter & Filter in Fuel Pump
    • Check Fuel Quantity supplied by the Fuel Pump
    Special Notes
    • When found in 2.0l TFSI:
      • Rest of World (RoW) check TPI 2014143, the Intake Camshaft might have a worn out Fuel Pump Cam.
      • North American Region (NAR) check TSB 2015153 (01-09-03 > 15-10-01 > 15-10-02), the Intake Camshaft might have a worn out Fuel Pump Cam.
      • North American Region (NAR) check TSB 2018183 (20-08-01) and verify the High Fuel Pressure Sensor (G247) Part Number
    Retrieved from "18725/P2293/008851 - Ross-Tech Wiki"
    Category:
    Categories
    Meta
    bez101's Avatar
    Jul 2008
    8,472
    bump
    bez101's Avatar
    Jul 2008
    8,472
    right its had a new HPFP and follower
    cam sensor fuel line that was a bit kinked (prob happend when hpfp was replaced
    fuel filter
    34
    What is your measured fuel pressure?
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
