Chris NottEM Tuning
Results 1 to 19 of 19
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    Lightbulb Wheel alignment cost.
    Hi all,
    Both front tyres have worn on the outer edges so would need to be replaced.So would you replace then get the wheels aligned or align then replace tyres.
    has anybody had their wheels aligned recently or what would the costs be ?.the car does not pull or tramline but it has hit a few pot holes over the last few months.
    any advice would be welcome,
    cheers,
    John.
    2.0 T Avant quattro s-line.2005
    North East
    568
    I have just had my wheels aligned in the last month so here's my story;
    Two new front tyres fitted and balanced, steering wheel off centered so had four wheel alignment done for an additional £30 and thats here in the NE so the price is low. Steering wheel was still off centred so had it done again at no extra cost. Result was the steering wheel was still off centred and the company claimed my rear suspension geometry has some wear in it preventing them getting consistent results.
    I took the car to my local Indy who realigned the wheels in my presence ( took about 30 minutes and £20) and the car is now fine.
    Hoorah !
    26,720
    TBh costs vary, a guy got robbed for £165 the other day having his done & then complained he thought they could of done better, but £65 to £100 is acceptable on most good systems IMHO.
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Round my way they do FOC checks, them about £30 if it needs adjusting #Lincolnshire
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    Thanks for the advise guys,
    Paul B7 was your car aligned on a hunter type system or at local tyre fitting centre using mirrors sorry but its years since I had had an issue with alignment
    There are a couple of places near me that have either a hunter or Beisbarth four wheel alignment (4WA).I'm sure I read somewhere some places charge for the initial test then more for each adjustment or for each half an hour need to make the adjustment.
    does this sound right.
    Anyway still need new tyres !!!!!
    cheers,
    North East
    568
    Quote Originally Posted by John@mk View Post
    cheers,
    I don't recall the make of system but both used laser based systems if this helps.
    AudiB7Jay's Avatar
    Nov 2012
    354
    Quote Originally Posted by Richardesty View Post
    where in Lincolnshire? :o I've been quoted £75 everywhere I go
    26,720
    Thats reasonable £75, whats wrong with that.
    AudiB7Jay's Avatar
    Nov 2012
    354
    my bad forgot to mention its not even laser adjustment it's the old light n mirror jobby
    26,720
    Urmmmmm, maybe little bit much, but then again how longs it take them, electricity, equipment costs, they dont get £75 in hand, so overall its not exactly expensive.
    AudiB7Jay's Avatar
    Nov 2012
    354
    About 45 mins they said, looking at the rig they use I doubt it was very accurate tbh
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by Paul B7 View Post
    Hoorah !
    Having the same issue with my steering wheel being off centred. Not sure whether to get alignment done when I have my new tyres fitted or before.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Alva78's Avatar
    Nov 2012
    Kent
    43
    The Hunter system is briliant Elite in Essex is very good and very reasonable .My old Golf mk iv was slammed 50mm and was spot after realignment by them
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    got through the pro align which use the hunter system and the local garage charges £85.00 plus vat,then spoke to APS who use the Beisbarth four wheel alignment (4WA) system and charge the same!!! the guy (Ian?) said the the rear wheels on the quattro are adjustable ?thinking this is the way to go as it's less than a new tyre......which I will go through if not sorted out...
    ordered the new tyres today so will get back with an update once fitted and aligned.
    cheers and enjoy the snow....
    North East
    568
    The rear wheels on the 2WD units are adjustable as well.....................Good Luck !
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    Now had the tyres fitted now waiting for the whjte stuff to go
    Found a place in MK that use the Hunter system for £45 plus vat.So report back when alignmet sorted....
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Is that price for a full 4 wheel alignment or just tracking?
    Az
    Euans2's Avatar
    Nov 2012
    Scotland
    36
    It's about £40 for a 4wheel laser alignment in Edinburgh
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    The price is £45 plus vat then x plus vat for any adjustnents.As I was advised to go to this tyre fitters by one of the local indy's who also send them all their alignment work they said they will do it plus adjustments for £45 plus vat.
    We shall see.....but after the snow has gone
    Two other places in MK where going to charge £99 plus vat but this include any adjustment, this was using the audi system.
  1. Four wheel laser alignment - Cost and location??
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2010, 13:41
  2. 200 for wheel alignment?!?
    By imported_shkwav in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2007, 19:10
  3. Tracking/wheel alignment
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2005, 10:17
  4. AMD Wheel Alignment - Had it done ? Comments please
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2005, 18:57
  5. wheel alignment
    By JayBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2003, 16:57
