EM TuningAH Fabrications
Thread: Tyre choice
    MGTURBOM's Avatar
    Oct 2006
    76
    Tyre choice
    Hi folks,
    I've just got hold of a set of Audi A8 19 inch rims. Im planning to put them on my A4 3.0 tdi cabriolet. Checked the offset they are ET44...current wheels are ET43. Im planning to put 235/35's on the front but I'm thinking about going a little wider on the rear. The current setup is 235's on the front and 245's on the rear. The new rims are 9J. I'd just like a bit of guidance on how wide I could go on the rear...I was thinking 255/30. Appologies if this has been discussed before...I have'nt managed to find a suitable thread with the information I need. Any suggestions appreciated?.....
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    You may well need spacers to clear the front brake calipers, just FYI. Not sure on the limits for tyre widths on 9j, I will let someone else chime in...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    821
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I bought a set of a 19" 8.5j A6 Le Mans Edition wheels (RS4 style) recently and they came with a set of 255/35/19 tyres fitted. Already had 15mm spacers on the rear so no rubbing issues there. But rubbed with 5mm spacers up front so had to fit 10mm to clear.
    I have been told that 235/35/19 should be fine however but not sure if 245s would be better and just run 5mm spacers up front.
    There are some visual wheel offset/fitment guides available online which should give you a good idea on what options you have.
    Az.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    MGTURBOM's Avatar
    Oct 2006
    76
    Thanks for the advice people. I did consider whether the caliper may be an issue and also wondered whether 235's would look too small on the rim. I think 255's on the rear is the safe option, there is a temptation to go wider but I dont want the car to look OTT!
  1. Tyre Choice - Opinions Welcome
    By MattS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd February 2007, 11:37
  2. Tyre Choice - A6 1.9TDi Sport Saloon
    By mickey_a6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th March 2006, 12:54
  3. Tyre Choice
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd December 2004, 19:52
  4. Tyre Choice - that time of year...
    By imported_DrOdius in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2004, 11:21
  5. Tyre choice for an S3
    By Nogaro in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2003, 11:25
