Results 1 to 12 of 12
    Nov 2011
    Sheffield
    31
    So, my car's possesed
    This issue started randomly 2 days ago.
    I have the Audi Symphony with Bose and a parrot kit. I've had it for 1.5 years and I've not attempted magic of any sort.
    As demonstrated in the video. Once I remove the keys from my ignition after about 3 minutes, the speakers pop quite loud and the hissing begins from the speakers. When anything that consumes power such as locking/unlocking of the doors or the lights being turns on and off the funky 8bit sounds kick off. However, the second I tap the power button the HU, it's sorted.
    Right now, as my car is parked up, the HU is on probably on; chanting the sound of its people.
    26,716
    Amp problem maybe.
    Nov 2011
    Sheffield
    31
    Amp problem maybe.
    That did spring to mind but care to elaborate? Not quite sure where to begin in getting this resolved.
    26,716
    Could be a faulty amp is still providing some power to speakers, when no sound is being pumped through as such, as in its not being told to switch of when radio's of, not sure its the best explanation but its been a longgggggg day
    May 2012
    UK
    178
    is the sound coming from the radio (unit itself) or is it coming out through the speakers?
    if its coming out through the speakers. disconnect the parrot hands free kit and see if the sound is still there. it might be the parrot causing the issue
    Nov 2011
    Sheffield
    31
    Through the speakers. Do you mean remove the HU and the parrot from the HU?
    May 2012
    UK
    178
    Try removing the head unit and test it. if there is sound it's the parrot. If the sound is gone its the head unit
    If the sound is still there revert back to oe by removing the parrot and seeing if the sound is there
    If the sound is there it could be the amp
    Nov 2011
    Sheffield
    31
    I will give that a try. The car is now dead and is refusing to turn over :-(
    Where would be the best place to check out in sourcing an amp?
    May 2012
    UK
    178
    I think ebay is your best bet for a amp. its located in the boot on the driver side behind the carpet cover
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Quote Originally Posted by DarkShadow View Post
    ..........Where would be the best place to check out in sourcing an amp?
    I think the best guy to source one from would be the very guy who's just advised you what the fault may be; Nigel (NHN).
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Nov 2011
    Sheffield
    31
    After my car died, that seems to have fixed the problem
    May 2012
    UK
    178
    did it die because the battery was flat?
    if so it could be the sound of the parrot dieing or the parrot sending a signal to the amp and then dieing because there is no power and then turning back on and dieing. if you know what I mean
  1. someones twatted my car
    By danksy in forum General Chat
    Last Post: 18th January 2003, 22:29
  2. What kind of company car do you get?
    By worfke in forum General Chat
    Last Post: 13th January 2003, 08:58
  3. where can you post cars for sale?
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 18:30
  4. My first car;
    By richyboy in forum General Chat
    Last Post: 10th January 2003, 15:52
  5. Wedding Car
    By Drystone in forum General Chat
    Last Post: 7th January 2003, 08:48
