Monster MotorsportChris Nott
Results 1 to 24 of 24
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    I Pod adaptor 2006 A4
    Im new to the forum got my A4 2.0 TFSI SE B7 about 2 months ago went from a 2000 mondeo to this and I think I'll be buying Audie's for the rest of my life now what a car very happy.
    Anyway I want to install a I pod adaptor but my stereo is single din and has an internal CD player and no option for cd 1 or cd 2. Does this mean a I pod adaptor will not work?
    I have looked at the connects 2 products and they all seem to use the cd changer connection so I'm presuming they don't work with out cd changer.
    Any help would be greatly appreciated thanks.
    Nov 2008
    389
    You'll be fine. The single din stereo will have the cd changer pins available on the back so iPod adapter will plug in with the right cabling (supplied with the device normally)
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    That's great thanks I think ill order that 2mor sick of burning cd's.
    Nov 2008
    389
    Just remember that no track names are shown just track 01,02 etc. don't want you being disappointed...
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Ya not bothered about the track names, just when I press the CD button I only have the option to play the cd in the stereo there is no cd changer option like CD01, CD02.
    bleedout's Avatar
    Sep 2012
    Musselburgh, Scotland
    69
    And ipod adapter or aux in cable will utilise the cd changer plugs in the back of our headunit.
    What you may have to do is have the coding for a cd changer turned on via VCDS. That way the headunit will treat the ipod like a multichanger seen as you dont currently have one fitted.
    Driver of the big Blue English Springer Spaniel bus........
    Ownded Cars:
    140 BHP A4 Avant "Spaniel Bus"
    300 BHP Focus ST3
    150 BHP Astra Sporthatch
    130 BHP Stealthed out DERV Corsa
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Thanks Bleedout, have the coding for a cd changer turned on via VCDS is this something I could do or would i have to get an audio instalation pro to do it.
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Ok I have done some searching online and found that you need to get VCDS software and cable but it is possible. I don’t fancy spending 250-300 pound getting the gear and not being able to use it plus I don’t have the time. Is there anyone in the Liverpool area that does VCDS alterations for Audi A4 2006?
    Nov 2008
    389
    Not convinced you'll need to do any coding. I've done quite a few in the past and no coding required- just physically plugging into back is enough...
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Thanks Phil I have ordered connects 2 adaptor cos either way ill need that, should be here Mon or Tue so ill see hope your right that would save a lot of messing.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    Quote Originally Posted by phil_w View Post
    +1
    The CD changer (or equivalent aux in or iPod adapter) just works without making any coding change.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jord_C's Avatar
    Apr 2012
    Grimsby, UK
    61
    Ive been looking into this also. But ive found that the Dension GW17AC1 looks to be a safe bet!
    Anyone on here got one installed with a concert II? As i can only really find people who have installed them with the symphony system! And was just wondering how user friendly it was to use, before i go blowing 130 on it! Lol.
    CjB, you will have to let me know how the install goes, as im curious as to what it will be like! :-)
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    No problem Jord_c it should be here 2mor so ill have a go at install 2mor evening and let ya know.
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Ok so I connected it all up connected my I pod and noting if you look at the picture below you can see CD on the screen this is all that comes up no CD1 CD2. Sorry about the size of the picture.
    Nov 2008
    389
    If I remember correctly you press the cd button either twice or more to cycle into changer mode?
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Pressed the CD button twice,three times also held it in for a few seconds no joy.
    Nov 2008
    389
    A quick test here:
    CD Changer Detection
    The following is the procedure on how to check if the radio detects an externally mounted CD changer.
    Turn off radio.
    While pressing and holding the MODE button, turn on radio.
    The display shows CONNECT if a CD changer is connected. Otherwise it shows NO CDC. This is a display-only mode. You cannot change any settings.
    When you are done, turn off radio, then turn it back on for normal operation.
    Nov 2008
    389
    Whoops - no mode button...
    Nov 2008
    389
    Right - done some digging and the consensus seems to be that some concert II headunits come precoded for cd changer connection and some don't , seemingly at random. I must have just been very lucky (5+ times)
    See link here - suggests that you may, after all need a VCDS friend for a 2 minute tweak...
    http://wiki.ross-tech.com/wiki/index..._Generation_II
    Cjb
    Cjb's Avatar
    Jan 2013
    Liverpool
    14
    Thanks phil_w VCDS it is then just my luck thanks for all your help greatly appreciated ill let ye know if I get it sorted.
    Nov 2008
    389
    I'm sure there must be some friendly Liverpool types in here:
    http://www.audi-sport.net/vb/vcds-fo...%2A%2A%2A.html
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    Quote Originally Posted by Jord_C View Post
    My car came with the Dension and concertII, I think its brilliant!! Dead easy to use, displays all track info on the dash, easy to scroll through playlists, tracks, artists from the steering wheel controls. Can't fault it to be honest, had a Xcarlink in my last car and its streets ahead of that.
    Jord_C's Avatar
    Apr 2012
    Grimsby, UK
    61
    Quote Originally Posted by ajax1976 View Post
    Thanks for your reply ajax! Looks like i will be getting one ordered in the next few weeks then! :-D
    AudiB7Jay's Avatar
    Nov 2012
    354
    Are these kits plug and play?
  1. i pod/ iphone adaptor\plug in??
    By frank s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2011, 19:09
  2. Dension / Audi I pod Adaptor or Harmon Kardon?
    By Lenaldo in forum In-Car Entertainment
    Last Post: 28th September 2006, 15:52
  3. Santa Pod
    By amoffat in forum Other Brands & Models
    Last Post: 10th March 2003, 23:32
  4. Santa Pod 16th March 2003
    By RichA3Turbo in forum Major UK Events
    Last Post: 9th February 2003, 18:20
Tags for this Thread
