EM TuningAH Fabrications
Like Tree1Likes
  • 1 Post By Richardesty
Thread: DRL/ Side light Load Resistors
    May 2012
    UK
    178
    Right I have had a search on a few forums and it is unclear what load resistor is used for what.
    I have only found DRL's but it would be helpful if someone posts up Numberplate lights and front side lights too
    DRL
    led drl bulbs with resistors installed (pics)
    Claims to use 25ohm 25watts on DRL's
    LED DRL's finally
    Claims to use 10ohm 25watts on DRL's
    B7 Audi A4, S4 and RS4 LED Daytime Running Lights (DRL) | Nick's Car Blog
    Claims to use 25ohm 10-15watts on DRL but in the picture he uses 15ohms 25Watts
    How to fit LEDs to the RS4 B7 DRLs
    does not specify
    I was wondering if someone can post up what they have used?
    Darren
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Personally I've used 10w resistors when replacing sidelight bulbs (one per bulb), 25w resistors for DRLs (21w bulbs - one per bulb) - just one of these for a pair of numberplate lamps - and 50w resistors for H11 fogs (one per bulb). All from eBay 'load resistor' search.
    Darren198712 likes this.
    May 2012
    UK
    178
    what would you use for the ohms though?
    would these work for the DRL's on the A4 ?
    25W 25OHM LED RESISTER CANCELLER Flashing Brake Light Side DRL Day Time Flasher | eBay
    May 2012
    UK
    178
    bump anyone ?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    Quote Originally Posted by Darren198712 View Post
    Start by assuming that the LEDs take so little current you can ignore them when calculating the resistor value. Then apply theses two formulae:
    Power = Voltage * Current
    Resistance = Voltage / Current
    Which means: Resistance = Voltage * Voltage / Power
    So for the resistor you need to make sure that:
    Resistor Wattage = same Wattage as the original bulb
    Resistor Ohms = 12 * 12 / (Bulb rating in Watts)
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
