JMB RetrofitsVolks Autos
Results 1 to 12 of 12
    Jan 2012
    Cambridgeshire UK
    26
    A4 2.0T FSI no power above 3000 revs??
    Hi Guys,
    I have a 2005 A4 B7 2.0T FSI Quattro that has shown a low pressure fuel reading and now it has got no power above 3000 revs. I am pretty shaw it is down to the in tank fuel pump being shot. The pump does make a lot of noise but i just want to make sure it couldn't be anything else. Can anyone help me please?
    Tim
    Mar 2011
    112
    If it's noisy then it would seem that the pump may be at fault. If your fuel level is low have you tried filling up to see if it makes any difference. Only trouble then is if it is pump I think tank has to be no more than 1/4 full before you can remove pump from top of tank under rear seat.
    Jan 2012
    Cambridgeshire UK
    26
    The car has about half a tank of fuel at the moment. Why does it have to a certain amount in it to allow the pump to be changed?
    olethalb's Avatar
    Aug 2012
    314
    check your hpfp and follower
    Jan 2012
    Cambridgeshire UK
    26
    The HPFP seems to be ok and I have bought a new follower which I'm going to change when I do the LPFP pump. I've ordered a new pump today that is going to turn up on Friday so hopefully the car will be cured.
    Mar 2011
    112
    Quote Originally Posted by t111bul View Post
    Elsawin states that the tank must be no more than 1/4 full otherwise fuel spillage could occur. I guess its due to health & safety issues and that's Audi recommendation.
    Jan 2012
    Cambridgeshire UK
    26
    Ok I've changed the pump now and thank you for the advice Custardsuker, the fuel was at a decent hight not to be a problem. The car now feels much better to drive. It doesn't seem to be holding back, it starts much better too and the pump is a hell of a lot quieter.
    Mar 2011
    112
    Glad to hear you got it sorted and that it's now driving better.
    Dec 2010
    224
    What's the price for the in tank pump and the hpfp with new lifter is it a easy job to do
    Jan 2012
    Cambridgeshire UK
    26
    The in tank pump was £260 from Audi, it took less that half an hour to change from start to finish. I can't remember how much the new lifter was as i have had it laying around for ages. I don't know how much a new HPFP is as i haven't had to change it.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    around 230/260 for the HPFP the cam follower is just over 20 quid
    Dec 2010
    224
    Thanks guys
  1. audi a4 1.8turbo 1997 loss of power over 3000 rpm
    By audi.1.8T in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2011, 20:06
  2. 1.8T Beetle looses power at 3000 rpm
    By crusher in forum Volkswagen and other VAG
    Last Post: 12th September 2008, 23:08
  3. Noise at 2500-3000 revs
    By nobbya in forum General Technical / How To
    Last Post: 10th December 2004, 06:17
  4. Power Dips @ 3000 RPM on S4???
    By imported_grantos in forum Tuning
    Last Post: 12th August 2004, 13:35
  5. engine goes flat at 3000 revs
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 02:21
