Volks AutosChris Nott
Results 1 to 8 of 8
    Pedro_keil's Avatar
    Dec 2012
    Deepest darkest Kent!
    19
    Phone prep removal
    After having the new toy for a couple of weeks its time to start playing and pulling things apart (and hoping I can put it back together again).
    Basically I want to remove the physical phone prep from the centre console as I'm using the bluetooth. and the blank holder looks really sh!te just sitting there.
    Firstly can I remove the holder and not effect the bluetooth functionality and secondly is there a kit or way of filling in the HUGE whacking great holes in the dash??
    A4 Avant (B7) 2.0 TFSI SLine Quattro TipTronic - Ooooooosh!!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Hi,
    There are two types of phone prep; one has a cradle concealed inside the armrest, the other has a humoungous ugly cradle bolted to the side of the centre console on the passenger side. I'm guessing from your description that you have the latter. If so, then mine had the same arrangement when I went to view it, and I asked the supplying dealer if it could be removed. They said it could, but that it would leave two big holes in the side of the console, and there was no way of plugging them invisibly.
    In the end, I managed to negotiate the fitment of a new console, so no holes. Someone else will probably be able to explain how to remove the cradle but only proceed if you're willing to have the exposed holes on the console.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    27,107
    You can replace that area of the console, but as said it will leave holes for now until replaced.
    Pedro_keil's Avatar
    Dec 2012
    19
    Was kind of hoping that having the latter wouldn't mean having a couple of peep holes left behind.
    Cheers for the info and I'll get looking for a replacement console I might even look at making some sort of temporary bung / cover for the holes to to get rid of the bracket.
    27,107
    Only other option is to plastic weld it, sand down, paint, but thats a bit of effort & may be obvious.
    Pedro_keil's Avatar
    Dec 2012
    19
    Probably too much effort if it ends up being noticable. Although It'll probaly look better than the bracket and the bungs if I do it as a temp fix..............
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    Good luck with it, however you decide to fix it.
    Pedro_keil's Avatar
    Dec 2012
    19
    Thanks!
    I'll post some before and after pics if it all works out OK
  1. Phone prep help
    By beerglass in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2007, 00:02
  2. phone prep
    Last Post: 17th January 2007, 21:12
  3. Phone prep volume
    By JohnS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2007, 18:24
  4. GSM phone prep cradle
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2006, 23:33
  5. Adaptors for A3 GSM Phone Prep Kit
    By dik in forum In-Car Entertainment
    Last Post: 18th April 2006, 12:18
