Chris NottAH Fabrications
Results 1 to 12 of 12
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    List of things i want to do. What do i need??
    Right ive got a list of things i want to do. (well my mechanic) And wont to get the required parts for him. So any help on what i need would be great. Im a real novice when it comes to car parts
    *Remove the intakes to do some decarboning around valves etc
    *Drop the sump and desludge/ replace pickup (engine very ticky and had oil sensor flash up recently)
    *Fit new clutch switch as i read they tend to be a common fault and i have jerky gear changes. Thought id try switch before DMF/Clutch
    *New temp sensor (gauge never seems to move once warm)
    So question is what parts do i need? Gaskets, Sensors etc....
    If someone could find me parts numbers it would be really helpful as my local dealer doesnt like giving them out if im not buying from them. And TPS arent always to sure.
    P.s
    I also keep getting these codes:
    MAP/MAF <-> Throttle Position Correlation
    P0068 - 007 - Short to Ground - Intermittent
    Air Intake System: Flow too Low
    P307A - 009 - Open or Short to Ground - Intermittent
    Which i assume is probably a dirty MAP sensor from the K&N filter???
    Thanks in advance
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    if your mech is any good he will tell you what you need get a list from him
    also for those parts you really need oem so get them from audi they good on prices for the parts you need.
    bez101's Avatar
    Jul 2008
    8,534
    but if the mech cant help you with a parts list id be going to someone who knows.
    rizzini7's Avatar
    Jun 2011
    728
    Was more the fact im planning on getting the parts through TPS as i get discount there and theyre so much more helpful if you know the exact part you need and part numbers. And i thought id ask the guys who have already done theres
    g00se's Avatar
    Nov 2010
    Reading
    265
    every K&N panel/cone/CAI kit ive had has monkeyed up a MAF... i steer clear now, and havent had an issue with Carbonio/ITG or BMC
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    rizzini7's Avatar
    Jun 2011
    728
    What i was thinking. The filter was fitted when i got the car. Are the Pipercross/BMC panel filters ones any better?
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by rizzini7 View Post
    how long ago was that? sounds like it would be worth replacing.. BMC Panel Air Filter A4 B7 Avant / Saloon 1.6, 1.8T, 1.9TDi, 2.0FSi, 2.0T FSi, 2.0TDi, 2.7TDi, 3.2 V6 01/05> - £48.50 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspensio
    i threw a BMC panel in my S4 a couple of yrs ago, and have since given it a few cleans and not had a single prob with it.
    Ive not tried a pipercross
    goose
    Current:
    Past:
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by g00se View Post
    goose
    the carbonio i had on my R32 was by far the best quality kit ive tried...
    goose
    Current:
    Past:
    rizzini7's Avatar
    Jun 2011
    728
    Might order a BMC one and get it fitted at the same time as i assume the MAP if gonna need to come off and given a good clean. Got the car June 2011 and who knows how long the filters been fitted. I take it the fact the codes come up as Intermittent is why the warning light hasnt come on?
    g00se's Avatar
    Nov 2010
    Reading
    265
    its best to clean MAFs with either a proper MAF cleaner or electronics cleaner.. if youre going to clean it with alchohol, make sure you let it dry thoroughly before re-installation.
    give the MAF itself a clean by all means.. but if i were you, i'd pick up a new MAF sensor as well as the new panel filter
    may improve your mpg too!!
    goose
    Current:
    Past:
    rizzini7's Avatar
    Jun 2011
    728
    Yeah a rise in MPG would defo be a bonus .
    rizzini7's Avatar
    Jun 2011
    728
    Typical, went to Audi for prices and part numbers and got told. "We don't give out part numbers"
    Was also told mine doesn't have a pick up pipe and is part of the pump. Anyone know if the pump has a filter that can get blocked?
  1. LIST OF AUDI BREAKERS WANTED
    By mystic.bertie in forum General Chat
    Last Post: 4th March 2011, 22:54
  2. Car back from the service with a longish list of things to be done
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2009, 19:32
  3. few things i want to do to my B5
    By Rutter in forum Photography & The Digital Darkroom
    Last Post: 20th May 2009, 05:03
  4. List your experiences with modifying things with vag com
    By S3MHT in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th September 2006, 12:49
  5. Springs, things and lowering kits: Advice wanted please!
    By sausagefingers in forum Handling
    Last Post: 4th February 2005, 20:35
