Sky InsuranceAH Fabrications
Results 1 to 28 of 28
    Jan 2013
    14
    Defrost flap and heating problem
    Hi there
    Sorry the first post being a problem but need some help
    I have a S4 2005 and I have a problem with the defrost flap not moving and no heat for the passagner but all fine on drivers side.
    I have done some work myself and found where one the problems could be. I have found this picture of the motors behind the glovebox and where i have put one of the arrows pointing at the green arm that is missing in my car. Any ideas where i can get this from or a part number?
    Also which motor controls the heating for the passanger side?
    Any help with this would be great.
    Macdoon's Avatar
    Essex
    1,488
    Welcome to the forum fella, can't help with your issue but i'm sure someone will be along to help, but for my twopennith worth "don't let anyone in your passenger seat " lol
    Post a pic of your car too
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    IIRC it's the bottom motor (the one with the orange linkage) that controls the passenger side heating.
    My passenger side was only blowing cold air about a year ago, on investigation there was nothing wrong with the motor but the linkage had shifted slightly and jammed so all I had to do was remove the motor, unjam the linkage and refit the motor.
    BTW you can use the output tests on VCDS (VAG-COM) and watch the motors move.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Oct 2012
    Stanley, County Durham
    148
    Hi, can't see your picture, but I had the same problem with my B6 cab, that it the defroster wouldn't open/close. It's the one with the green linkage which operates the defrost flap. I have done a temp fix of removing the motor and opening the flap by hand and leaving it open. There is a thread in the B6 forum somewhere of people opening the motor, regressing and putting back together, and hey presto! The motors new I think are about £75!
    i can't help on the passenger heating issue
    Jan 2013
    14
    Wow nice and quick replys cheers guys.
    Ok will look at the motor with the orange linkage.
    Any ideas on where i can get the green linkage that links in for the defrost part as this is missing?
    chrisa4quat's Avatar
    Sep 2004
    897
    Plug it in should give you a v number. Defrost flap on a4 should be v107 I think
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Jan 2013
    14
    Hi
    Its not the motor i need it’s the green arm that connects to the linkage i am having trouble finding.
    Sep 2004
    897
    Comes with it if I recall
    Jan 2013
    14
    Hi Chris
    Thanks for the reply and help.
    I have managed to find a company that specialize in braking Audi's so got the defrost flap linkage for £30
    Jan 2013
    14
    Hi Guys
    Hope you are all enjoying the snow.
    Today I went to fit 2 new motors, one for the defrost flap and one for the passenger heating.
    Problem is both still do not move when turning on the defrost or heating. I dont have them connected to the linkage just hanging free but connected to the plugs. Any ideas what else I can look at or am i going to have to bite the bullet and take it to a garage
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    Quote Originally Posted by lucasuk View Post
    Have you checked/cleared any fault codes in the climate control?
    Plus try using the output test using VCDS, that exercises all the motors and the blower fan.
    Jan 2013
    14
    Quote Originally Posted by PetrolDave View Post
    How do you I clear the vault codes and I dont know what you mean by using VCDS for output test?
    Jun 2011
    Great Melton Norfolk
    1,340
    Have you scanned the car for faults with VCDS?
    Jan 2013
    14
    Ok managed to get a cable and software
    Codes that are coming up are
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Part No: 8E0 820 043 AM
    Component: A4 Klimaautomat 2728
    Coding: 00000
    Shop #: WSC 06325
    7 Faults Found:
    00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
    30-10 - Open or Short to Plus - Intermittent
    09-00 - Adaptation Limit Surpassed
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    41-00 - Blocked or No Voltage
    00716 - Air recirculation Flap Positioning Motor (V113)
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    So its not happy. Any ideas what to look at next. Did try clearing the codes but they came straight back
    Jun 2011
    1,340
    Have you gone into hvac and tried to run test to hear the motors/flaps working?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    Quote Originally Posted by gen.heinz guderian View Post
    We've suggested that to lucasuk before, but he doesn't know how to run the output test...
    lucasuk - when you open the HVAC controller in VCDS look at the screen on the PC and you'll see a button which says "Output Tests-03", click on this and a menu will come up that will guide you through testing the various motors.
    The interactive on-line VCDS manual will show you what to expect Ross-Tech: VCDS Tour click on Select, then on 08-Auto HVAC, and then on Output Tests-03.
    Jan 2013
    14
    Ok thanks Dave. Not had a chance yet to do this but will try it over next few days.
    Jan 2013
    14
    Ok update.
    I have run the output test-03 and both motors move. I have reconnected them to the flaps and rerun the test and again all is good.
    If i run the full scan i still get all the errors as above.
    What do i do next?
    Jan 2013
    14
    Hi Guys
    Anyone got any ideas what i can do here to get this working. Is this pointing towards the CC unit its self not working?
    Jun 2011
    1,340
    Have you cleared the errors after you have scanned it? Go into Hvac , check fault codes and clear again .
    Jan 2013
    14
    I am sure this is what i did. Can i just check to make sure I am doing things in the right order.
    I did a complete scan and I see the errors. I clear the errors then re run but they are still there.
    Is there something i have to do after i clear the errors?
    Jun 2011
    1,340
    Do the blower fans work when you run the output test?
    Jan 2013
    14
    Yes all motors and blowers working fine with that test.
    Jun 2011
    1,340
    Ok ,when it is all back together does the heating/cooling work as normal?
    Not using vcds .
    Jan 2013
    14
    No the motors dont move when I am using it through the standard controls on the CC
    Jun 2011
    1,340
    have the buttons failed then?
  28. #27
    Jan 2013
    14
    Well think the buttons are fine as I can hear the air change position but the motors don't move.
  29. #28
    Jun 2011
    1,340
    Not sure what to suggest next, sorry.
  1. Replies: 10
    Last Post: 26th November 2012, 01:19
  2. KEY AND LOCK PROBLEMS!
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2007, 11:08
  3. Claimate Control/No Heat problem
    By LeonardSkinner in forum General Technical / How To
    Last Post: 1st November 2006, 22:01
  4. FSi-Lumpy idling and starting problems
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 16:00
  5. washer tank and motor problem
    By imported_stanA3turbo in forum General Technical / How To
    Last Post: 1st January 2005, 22:00
