AH FabricationsJMB Retrofits
    Jan 2013
    30
    Exclamation Turbo actuator pipe off. Causing issues when connected
    Hello everyone, so on day 3 of my Audi a4 2.0 tdi issues. Was not sure if the timing belt had been done, so I had that changed yesterday for piece of mind. I also had it put on the diagnostics and it came up with a P0299 fault - 000 - control range not reached. I was told that on inspection the turbo actuator pipe was off and this could cause me issues. So they refitted it and the car idles fine but once revved will not go over 2 thousand revs. Does this mean my actuator is stuck? Or could it be the vnt turbo vanes that are stuck. Tried it myself this morning and issue confirmed. When you remove the actuator pipe you can hear that pressure is released. Then the car seems to run ok.
    regards
    james
    Jan 2013
    30
    Anyone?
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    you could loosen the actuator and wiggle it to see if it opens.
    Had a similar problem on a mates car.
  1. cat pipe turbo side came off
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2010, 19:53
  2. New MAF & power cuts off when connected
    By DeeBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2007, 13:24
  3. Turbo Intake Pipes
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2005, 18:06
  4. Neuspeed 1.8T Turbo Intake Pipe
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2004, 17:22
  5. Turbo Intake Pipes
    By gbhdavies in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2004, 09:10
