Chris NottSky Insurance
Results 1 to 9 of 9
    Jan 2013
    30
    Exclamation Stuck temperature needle
    Hello, just bought my first Audi a4 2.0 tdi, all was ok when I paid for it and it was started from cold and ran fine all the way home and warmed up fine to 90 on the temperature gauge. I have come to get in it this morning and the gauge is still sat at 90. The car has been stood for we'll over 12 hours plus. Any ideas what this could be? Have my Haynes manual and tools at the ready
    james in sale in Manchester
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    There's no way it would still be that temperature after a night in the cold. Probably a stupid question but could anyone else have used the car before you got to it this morning?
    Does the temp gauge still read 90 when the key is out of the ignition??
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Jan 2013
    30
    Yeah, no one has used the car, still sat there with keys out. Thanks for the quick reply mate
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Normally when the key is put into the ignition and turned to the first position that's when the temp & fuel gauges 'energise' and show an accurate reading, before that they should be sat at 0 (all the way to the left).
    Perhaps try running the car today and see if the needle drops back to 0 after it cools again. If this fails you can take the dash apart and potentially replace the servo/motor. Doubt you would be able to get a motor on it's own to replace it though... hopefully you won't require a new dash. That seems a little extreme for a fault temp gauge. How old is the car? Still have an Audi Warranty? If you do take it there ASAP before taking the dash apart
    Jan 2013
    30
    Car is a 2005. So wont have a warranty. Will give it run out today and see how it goes.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Re: Stuck temperature needle
    Change the coolant temp sensor.
    A4 (b6) 2.5 TDi QS Saloon.
    Jan 2013
    30
    Would you know the part number? Also I believe some models have 2 is this correct?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    take it back where you got it from
    Jan 2013
    30
    It was a private sale
  1. Where does your A4 TDi temperature needle sit?
    By AudidriverA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th February 2013, 18:04
  2. LAZY temperature needle !!!!
    By boostboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2010, 20:17
  3. Temperature gauge on an Audi80 2.0e 1994
    By yorky068 in forum Classic Audi Forum
    Last Post: 14th July 2006, 00:47
  4. stuck radio
    By bredhurststeve in forum In-Car Entertainment
    Last Post: 24th September 2003, 12:56
  5. window stuck unstuck
    By gregmmm in forum General Technical / How To
    Last Post: 9th June 2003, 18:05
