Chris NottAH Fabrications
Results 1 to 12 of 12
    May 2012
    UK
    184
    Custom headlights DRL (aka Flystrips?)
    I had a look on youtube and seen this video
    AUDI A4 B7 CUSTOM HEADLIGHT LED - YouTube
    I was wondering where can I get these type of DRL's or is there any how to guide.
    I noticed that on the "Clear Corner Mod - How To Guides" there are similar headlights modified like this
    http://i31.photobucket.com/albums/c3..._6407Large.jpg
    Darren
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    this is Phills modd, he makes the Fly DRL you can find him at audizine fly300kts
    Audi A4 2.0TDI 2007 B7 S-Line & Proline
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    For more pics visit my FB http://www.facebook.com/MR.Doberlluka
    For all my mods visit http://www.garaget.org/lenti
    and http://www.audizine.com/forum/member.php/73213-lenti look @ my started threads
    May 2012
    UK
    184
    DIY FTW!!!!!!!!!!!!!!
    Jan 2012
    Lincoln
    138
    They look great, good work
    May 2012
    UK
    184
    sadly no progress on these lamps as I am waiting for my new Hot glue gun to arrive in the post. I ordered it on the 11th of Jan and its still not here!
    I think I am going to put 9 or 10 white led's accross the bottom and in between the white led's I might put amber and wire them up into the indication lamp.
    May 2012
    UK
    184
    updates. my hot glue gun has arrived. I will carry on with my project this week :-)
    only problem is I only have 2 glue sticks (should be enough but I have ordered more)
    I will keep it you guys updated!
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    They look awesome! WANT!
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Feb 2008
    281
    Quote Originally Posted by Darren198712 View Post
    The lights look the nuts.
    the other thing though, pc and tissues dont look good in the same picture......say what ya see.
    AudiB7Jay's Avatar
    Nov 2012
    374
    Quote Originally Posted by A4_MaJiK View Post
    lol there the exact ones I used in the same place n you didn't like them :o
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Quote Originally Posted by AudiB7Jay View Post
    Really!? When?
    plymouthaudi's Avatar
    Jan 2012
    88
    Better idea follow this website looks the business. I done this in about 1hr and looks amazing and oem to very bright.
    http://forums.vwvortex.com/showthread.php?3952827
    A3 8P 2008 2.0 TDI 170BHP S Line
    :-Remapped to 210BHP
    :-Pressed Number plates
    :-Xenon Lights 4300K
    :-Footwell Light Retrofit
    :-LED Interior Conversion
    :-Stainless Exhaustf
    :-DPF Removed
    :-RS4 Bucket Seats Retrimmed
    :-Boot Tool and Air Compressor Build in the making
    :-Drilled and Grooved Discs and Brembo Pads
    :-Callipers Painted Red
    BlackVue DR380G-HD Fron camera
    May 2012
    UK
    184
    not a full step to step guide but here we go
    follow DIY: CC (Clear Corner) Mod
    to split the head lamps open
    for this you will have to paint your inner head lamps black.
    This is a "how to" guide on how to fit DRL lights similar to the fly kits.
    I do not hold any responsibility for any damage done to your car.
    What you need
    Hot glue gun
    5mm Led's pre-wired with resistors 30-40 of these in white
    Masking tape
    Pencil
    soldering iron
    solder
    insulation tape
    1 meter of 12volt 5 amp cable
    Plastic primer
    Satin/Matte black spray paint
    degreaser before you paint
    torx screw driver
    right once you split the head lamps open from the guide above, all you need now is the clear plastic and the head lamp chrome bit
    test all your led's that are the same color and are white
    stick masking tape on the outer lens and there will be lines on the lens. count the lines
    I think there is 32 take 2 away (one from each outer side) and then depending on how many led's you want work it out and ect
    I went for 10 Led's as it was like every 2.5 gap or something like that
    remove the chrome and stick masking tape on it (3 torx screws)
    plug in your hot glue gun and leave to run while you work from now if you wish (pre heating it as it takes quite a long time to heat up)
    place the chrome back into the lens and use a pencil and mark the lines from the outer lens to the inner chrome using a pencil and remove the chrome bit again
    2 people would be preferred for this job.
    hold the chrome lens or prop it up upside down put a dab of hot glue on where the line is and put the led on the chrome
    do this for all the lines. it will take a bit of time as the glue does take a long time to dry so you will have to hold the led while it drys while the other person holds the glue gun.
    once you have done with gluing and everything has dried up strip all the wires back
    join the red to red and black to black and use thicker wire (support up to 5 amp) and wrap them around the wires red to red, black to black.
    screw the chrome back into the lens. it will be a tight fit but it will fit I had to trim one of the edges to get mine to fit.
    after that find a 12 volt power supply and connect the red and the black to the power supply source and make sure all the led's look in line and they are not facing the wrong way ect. (I used a computer to test my led's as computers output 12 volts)
    adjust the led's if you think they are on the wrong direction. remove all the glue using a flat blade screw driver and use a new led. it should rip the chrome off but that is not a problem as its underneath so you won't see it. re glue and test ect ect.
    once you are happy with the location of the led. degrease the chrome and make sure its dry. Use some masking tape and tape up the led's
    use some plant wire or what ever you call it and wrap it around the loop where the screws go through and hang it up ready to primer
    primer the part and wait for X amount of time so its dry.
    after the primer has dried paint with Satin/Matte black spray paint and leave to dry for X amount of time so it dry's
    once dry strip the all the wires back and join red to red and black to black you will need aprox 50cm of wire per lamp.
    once it has dry make sure the lens is clean from the inside and out side and make sure the light cluster is clean. remove the back cover of the bulb and feed the wire through to the back of the hole underneath the bulbs.
    drill the side of the head lamp and feed the 2 red and black wires out and hot glue to seal the hole where the wires go through.
    refit the "painted plastic / chrome" to the lens and use to de-globe guide and reseal the headlight
    Enjoy
    Darren
  1. A3 Chinese Headlights DRL, any good?
    By audi58 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2010, 21:40
  2. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
  3. New DRL / headlights
    By KKM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2008, 09:27
  4. DRL headlight function
    By cosmicblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2005, 12:48
