Volks AutosChris Nott
Results 1 to 8 of 8
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Anyone in or around London with VAG-COM? Need help asap!
    Hi all,
    My MOT is due by the 2nd Jan and at the moment, my airbag light is on. It's been on since I had my RS4 seats/retrim, but the car will fail the MOT as it is now due to the new rules.
    If anyone can help me with VAG-COM, it would be greatly appreciated.
    I'm in London (N6) but I can drive an hour or so in any direction if it means fixing this in time for the MOT.
    I need to get this sorted today/tomorrow ideally!
    Cheers,
    Matt.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,468
    VCDS (formerly VAG-COM) forum
    Try looking on the map. User dannykn9 is london based, ash187 as well try those two out. x
    Nov 2003
    London (N8)
    515
    Ah, cheers - didn't know about the map
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Bit of a distance to you but if you get stuck im available.
    Jul 2007
    London
    3,241
    I'm in Muswell Hill, N. London...
    FOR SALE:
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Im in Folkestone if adamss24 cannot do Sunday.
    I take it the seats were fitted before the re-trim without the light being on? As VCDS will only clear the light if the ‘fault’ is no longer present.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    27,099
    Yeah rs4 seats come with an oem resistor circuit built into the loom, it looks like it has airbags as has a yellow plug which most people denote as airbag present, but some unwinding of the loom tape shows the truth behind audi's mind, so maybe its either just cause been unplugged or someone has tampered with internal plugs/wiring.
    Nov 2003
    London (N8)
    515
    Ok, cheers all - I've spoken to dannykn9 and he's going to help me out this week.
    I think it's just a case of checking all the plugs are securely located and then clearing the fault code. I think we must have switched the ignition on with the seats out. Either that or it was when we switched the steering wheel over... or when I drove with the glovebox out & some cabling disconnected!
    Need to get it plugged in to see which it's likely to be
  1. Replies: 7
    Last Post: 4th October 2012, 21:41
  2. Anyone in the leeds are with Vag.com?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 08:48
  3. Anyone in the plymouth area with VAG COM ?
    By frenchman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2008, 19:18
  4. Anyone with VAG-COM to help setup Anti-Hijack door lock
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd February 2007, 22:04
