Results 1 to 14 of 14
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    B5 spring perch/seat confirmation
    Hi,
    Had my spring perches sitting in the garage for a few months now and decided tomorrow could be the day. Before I go any further though can anyone confirm that I have the right ones. I had the wheel off the other day and the ones I have don't look that different to the ones already on the car.
    The first picture looks exactly like the ones I have, part no 8DO 412 066F. When I googled for pictures of B5 spring perches the 2nd picture came up as well. It obviously looks different but I can see why it lowers the 15mm unlike the ones I have.
    Can anyone confirm if I have the right or wrong ones?
    Alan
    chrisa4quat's Avatar
    Sep 2004
    897
    I think it's the 2nd pic from memory when we did mine
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Mar 2011
    112
    When I did mine they were the same as the 2nd picture, but the first picture looks to me as though it is the same object as in the 2nd but with the spring mount fitted, also the originals on mine were an aluminium colour. Hope this helps.
    Sep 2004
    897
    As above. It the nail on the heas
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    Thanks guys, I'm definitely starting to think now I've bought the wrong thing. The 2nd picture to me looks like it would lower the extra 15mm as its a looks to have a lot more depth from where it sits on the shock and where the spring actually sits on it as compared to the one in the first picture.
    I got the part numbers from a thread on here that a guy called Macdoon had posted them,
    B5 lower spring perch plate
    I stupidly never read the rest of the thread as there's a guy who used the same numbers and fitted them then discovered his car is no lower.
    I'll need to do some more research for the correct numbers. Glad I double checked before I started tearing bits off my car, Thanks again Alan
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    This is what I have with the spring insulator removed, you can see it doesn't have the same depth in it as the 2nd picture above and theres no slots cut into it.
    Pretty sure these are what I should have bought, 8D0 4121 03B.
    EuropaParts.com: Lower Spring Perch Plate (B5) - 8D0412103B
    Mar 2011
    112
    Not sure what that one is as it's not the same as the ones I removed from my B7, looks all together different and its not the one that your looking for.
    The part number you quote 8D0 412 103 B is i think correct, bought mine from dealer at about £15 each. Its worth doing some preparatory work before fitting as normally its difficult to get the pinch bolt out that holds both top ball joints in place and once you've removed that it's sometimes difficult to remove the ball ball joints from the uprights. Don't be tempted to spread the slots, its not advised by Audi, soak everything and be patient, also worth getting new bolts and nuts. Then rebuild with plenty of anti seize compound.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    Quote Originally Posted by Custardsucker View Post
    Thanks for the tips, had them off a month or so ago for my springs so hoping they'll play ball again. I'll pop into Audi on Monday and order the new ones and bolts, hopefully the right ones this time!!
    You're right in that they look different to the ones I have on my car at the moment, sure the ones I have are cast aluminium but it was the dimensions that got me thinking. Just couldn't workout how the ones I'd previously bought could lower as the dimensions looked identical even though the part looked slightly different to the ones fitted.
    Anyway, I'll update the other thread that led me astray once I have the new ones fitted to save others the hassle and cost of buying the wrong thing.
    Thanks for all your help!!
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    Just an update, fitted the right perches today (8D0 4121 03B) and they did lower by 15mm, happy days!!
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    MAGIC!!!!!!!!!....................Great Info....
    Are these perches Dealer only or is it something you can get from GSF ect????
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
    Jan 2013
    Moray
    228
    Are these steel or alloy? As if i did decide to go for this mod, then i'd want them powdercoated.
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Alan.....
    How long a job is it to fit these out of interest????
    Also, I assume they are ok to fit with standard S-Line suspention???.........
    Privacy Glass
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    482
    Quote Originally Posted by Steve220 View Post
    B5 perches are steel mate, my originals were aluminium
    Quote Originally Posted by Tiffy View Post
    Alan.....
    I spent 2hrs yesterday freeing off my pinch bolts as they are notoriously hard to get out and checking over what I wanted to do, didn't want to get one side done then struggle or not manage to get the other side done.
    Today it probably took me 4hrs with plenty of tea breaks and lunch.
    Dealer or TPS, think you'll struggle to get them elsewhere.
    Found cheap pinch bolts on Ebay just in case yours don't come out whole, Worth buying purely as a back up.
    AUDI A4 TOP ARM SUSPENSION REPAIR BOLT KIT (PAIR) INC WASHERS AND LOCKNUTS | eBay
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    cheers mate..........
    Privacy Glass
  1. I've had my B5 spring perches for 8 months, are they hard to fit ?
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2 Weeks Ago, 22:37
  2. B5 lower spring perch plate
    By schmergal in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th April 2013, 23:43
  3. B5 SPRING PERCHES
    By holmefield in forum For Sale/Wanted - Audi Parts
    Last Post: 10th July 2012, 19:11
  4. Advice please help. Part numbers for B5 spring perches
    By jambofuz in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2012, 17:30
