Volks AutosEM Tuning
    Jul 2011
    middlesbrough
    112
    2006 A4 2.0TDi 140 Cutting out
    I have bought a 2.0tdi a4 se140 last week, from a vw audi garage the cars really nice but it keeps on cutting out. it first done it the other morning when i was defrosting it it just stopped but started again stright away. Then after setting off for work the other day it completely cut out when doing 30 and wouldnt restart for 20min i taken it to the garage where its under warrenty for 6 months and they plugged in the computer and said it wasnt showing any faults they said they had a few cars recently with dodgy fuel filters so changed it then ran it for a while and said try it then today when at idle it was like some one turned the ignition on and off quickly it died lights came on the dash then it picked back up just before the engine stopped.. I know its under warrenty but has anyone got any ideas? I dont want it to be in and out of the garage all of the time :/
    Regards Tom
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Hmmm, depends on if they actually have got a decent computer. Could be battery is on it's way out as I don't think that would be picked up by the computer.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jul 2011
    middlesbrough
    112
    they have the latest vagcom and bosch computers.. Batterys a thought i havnt heard of them doing that when its on its way out
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I know that sometimes a tired battery can cause all sorts of weird problems. Might also be the wiring between the alternator and the battery. When it's cut out are there any electrics?
    Nathan
    i_786_i's Avatar
    Aug 2012
    57
    Re: 2006 A4 2.0TDi 140 Cutting out
    Hi, sounds fuel related to me. Seen a similar problem once on a honda and was narrowed down to a fuel filter. Id get them to completely check the fuel line and run a diagnosis when the car is running. If it was battery related im assuming the display and lights etc would cutout at the same time?
    Jul 2011
    middlesbrough
    112
    Right been to garage couple of times recantly they have replaced fuel filter but the problem still persisted they have now tried fuel relay. The car isnt throwing any fault codes off at all so its a bit of trial and error..
  1. 2.0tdi 170 Quattro cut out, no fuel at filter
    By oli-lord in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd December 2012, 13:41
  2. 2.0tdi Glow Plug Coil Light Flashing, Juddering, Cutting Out.
    By bagger_12 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd December 2012, 18:36
  3. Audi A3 sportback 5dr 2006 2.0tdi 140 54K !!
    By reece-page in forum For Sale/Wanted - Audi Cars
    Last Post: 18th April 2012, 16:46
  4. Front brake disc size for 2006 A3 2.0TDI 140 FWD manual?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 18:50
  5. 2.0tdi cuts out after start
    By spencer361 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th March 2011, 22:32
