AH FabricationsJMB Retrofits
    Dec 2012
    2.0tdi 170 Quattro cut out, no fuel at filter
    Hi all, 07 plate a4 2.0tdi 170 quattro,
    Had problems in the past, cleaned EGR valve had new injectors etc.
    Cut out on the motorway tonight, engine turning over but no fuel even though theres half a tank in.
    Checked the filter and there was no fuel but not sure whether it was inlet or outlet to the filter as it was raining and only had a chance for a quick look.
    Just wondered if any body has had a similar problem and could point us in the right direction?
    chrisa4quat's Avatar
    Sep 2004
    897
    Fuel pump in tank?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Dec 2012
    yeh so far thats what we're thinking, we need to check for definite if it is getting fuel up to the filter or not yet, just wondered if anyone has had the same problem.
    thanks for your reply.
    Dec 2012
    anyone having a similar problem, water had got into the fuel pump casing and took out fuel pump relay and alternator relay
    thanks
  1. Audi A3 2.0tdi 170 quattro s-line 2006
    By HIGGINS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2010, 15:45
  2. A3 1.8t Quattro cutting out
    By spanner182 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2009, 11:44
  3. 2.0TDi 170 Quattro Avant - worst audi ever?
    By Keef in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th November 2008, 18:10
  4. 2.0TDI 170 Quattro Chip / Remap?
    By Keef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2008, 13:01
  5. help with quattro cutting out
    By mikehoncho in forum General Technical / How To
    Last Post: 27th November 2007, 21:12
