Results 1 to 39 of 39
    Jan 2012
    100
    help with springs??
    i have a 57 a4 1.9tdi s line and it failed an mot today due to a snapped rear coil spring.was told the price of a new spring was £70 plus £50 for fitting and i couldnt help but think its was a bit "harsh" for 1 spring.got me thinking about buying a set of h&r lowering springs for £175 and fit them myself.
    Was wondering if you guys think think you get a better ride with lowered springs(think i would have 40mm all round) or if the s line springs would be best?i know it would look better lowered as there is a gap between my arches and the wheels but wouldnt want to affect the ride comfort by lowering.
    Any info would be appreciated
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    SEARCH!
    Yes, the standard ride is pretty poor on s-line springs, aftermarket decent springs will improve ride quality, as well as give a better stance
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Jan 2012
    100
    i have searched and i have my own opinion,but hearing from people who have have the worked done usually tends to help!
    pistonripper's Avatar
    Aug 2012
    West Midlands
    34
    I can't say for H & R spring, but I have had Eibach springs in my Audi and they were brilliant, rode slightly lower, sharper handling. Although I hear that H & R are top quality springs...I know in the Mercedes forums they are all praises for them.
    Jan 2012
    100
    thanks for the reply pistonripper,ended up just gettin a new s line spring fitted as i just wanted the mot out the way.did want it lowered but just wanted the mot out the way.hoping my new 19" rs4s willl fill the gap instead when i get tyres for them
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by bizzab7 View Post
    If you're fitting 19s i'd be even more inclined to lower it!
    I had Eibach's on my old R32, and i have H&R's on my S4.. ride and stance are very similar.. talk to Damian at DPM on here, he should be able to advise whats best for you.
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    I second what g00se says. I got a set of Eibach lowering springs from Damian at DPM about three weeks ago. Top class information and service, and the car sits, handles and rides so much better than before.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Chets's Avatar
    Jul 2010
    20
    I fitted H&R springs on my s-line. They quote 40mm drop but as the s-line is already lower it dropped by about 20mm. I like the fact it still looks OEM but handling is definitely sharper and the MRS hasn't noticed any difference in ride comfort lol
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    I've got H&Rs, 30mm (because they don't do any lower for the cab), and the ride and handling is improved from stock. Coming from s-line setup.
    Also went to 19"s at the same time, and I think the standard suspension with 19" would be pretty bad...
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I now desperately need springs as had a rear passenger and could hear the wheels scraping
    I've never bought springs before so don't know what mm to get. Found these for £150, these okay or stock replacement. It's an S-Line with the 18" alloys:
    H&R Lowering Springs / Spring Kit for Audi - larkspeed.com
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jan 2012
    100
    think i will just get a set of lowering springs then as it seems everyone is agreeing its worth it.do u still have space after the drop and 19s jj?was thinking of lowering 40mm but dont want any rubbing
    Jun 2011
    245
    i have lowered mine on eibach sportsline 40/50 mm drop on my 56 plate s line and i am running 19 wheels with 45 offset and 15mm hubcentric spacers on rear 235/35x19 tyres ,the ride is much better than standard s line springs and i have had no issues at all with rubbing
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Torn between the eibach 40/50 and the H&R 35's. So you have no rubbing if you have passengers in the rear?
    Nathan
    Tiptronic
    Jun 2010
    Nottingham, UK
    824
    As davsa4 said, you can get away with a 45mm drop with no rubbing issues. To be completely honest I'd like mine a bit lower, but I didn't think coilovers were necessary for my purposes and 30mm was the biggest drop I could find. Not sure if that's because mine is a cab or a 3.0tdi?? But it sits much better and rides a lot smoother than standard.
    Jun 2011
    245
    Quote Originally Posted by Wrath View Post
    i
    have had 5 adults in my car with no rubbing issues
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,296
    I think you can't beat the stance of the Eibach Sportlines if you're just opting for springs.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Jan 2012
    100
    davsa4 car looks spot on.alloys look excellent with the way your car sits.torn between eibach and h&r now
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    480
    A couple of pics of my car just after my H&R's were fitted, they have dropped a shade more now, first is with 19" wheels 2nd with 18's. No spacers as yet but will hopefully get them fitted soon. I test drove a car with Eibachs and don't think there's any difference at all between them and H&R's regarding comfort, both are much better than S line springs.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I've gone for H&R's in the end, just got them today off DPM. Thought they were going to take another week to come
    Lucky really as I think one of the rear springs has gone as you can hear the rear tyre rubbing when doing 70
    Nathan
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    480
    Excellent, look forward to seeing pictures of them once fitted!!
    V6 Quatt's Avatar
    Feb 2008
    783
    H&R good Choice as the 3.0 TDI has a drop of 40 mil
    Torque the Torque
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Only managed to install the new rear H&R -35mm springs owing to the faff we had with our non-standard spring compressors, there wasn't a lot of room behind the wheel! So this is my car with stock springs at the front. Obviously the new springs haven't had chance to settle yet. Just have in mind the before pictures were of my shot rear springs:
    After:
    Nathan
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Hmmmm, now it seems every so often the fronts are rubbing. I assume the stronger springs at the back are doing that. Maybe I'll have to put them on sooner rather than later.
    Nathan
    Jun 2010
    South Wales
    69
    Are the shocks the same on the SE and the S-line.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by davsa4 View Post
    Car looks spot on! What width are your wheels Dav?
    I'm looking to run a similar setup and just bought a pair of B5 spring perches so looking to fit some lowering springs at the same time as I hear it improves ride quality, handing and looks much nicer.
    My current setup is as follows:
    Wheels = 19" A6 Le Mans Edition 8.5j ET48
    Tyres = Vredestein Ultrac Vorti 235/35/R19 Y
    15mm spacers on rear (ET33) and in the process of putting 5mm spacers up front (ET43) as I am getting rubbing on full lock without them.
    As I have a 3.0 TDI Quattro, I am limited to the following options available on the DPM website:
    - AP 35mm @ £158.75
    - APEX 40mm @ £124.00
    - Eibach Pro 30mm @ £189.00
    - H&R 45mm @ £186.00
    - Vogtland Sport 30mm @ £190.00
    - Weitec F-Series by KW 35mm @ £217.00
    Quite a few options as you can see and most people seem to go for Eibach/H&R from what I've seen. I want something that will give me the most improved ride and also won't affect the life of the S-Line shocks (leaning towards Eibach 30mm in particular here). Baring in mind I will have B5 perches fitted up front (15-20mm lower) and it is on S-Line suspension (20mm lower than standard).
    Would you say the Eibach's would offer better ride quality than the H&R's as it is only a 30mm drop as opposed to 45mm?
    Thanks in advance, Azeem.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    spannah's Avatar
    Jul 2007
    N.London
    238
    Quote Originally Posted by ajax1976 View Post
    Alex how low did u go?
  28. #27
    Jun 2011
    245
    Azeem
    wheels are 8.5x19 with an offset of et 45 ,rears have 15mm spacers so in theory et30 ,springs are eibach sportsline 45mm front(25mm on s line) 35mm rear (15mm on s line) ,drives much better than standard s line springs did
    if you fit eibachs pros on yours it will only sit 10mm lower than standard as slines are 20mm lower than standard ,as for h7r i have never run them so cant comment but have heard good reports from people who have .
    dav
  29. #28
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    480
    Quote Originally Posted by spence_star View Post
    35mm H&Rs
  30. #29
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Azeem
    dav
    Thanks, Dav.
    Any issues up front with that offset? I'm getting some rubbing on the arch liners on full lock with ET48. In the process of fitting some 5mm spacers (ET43) to try get rid of it.
  31. #30
    Macdoon's Avatar
    Essex
    1,569
    I'm looking at getting Eibach 40/50 springs, has anyone got a pic fitted with 18's on.
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
  32. #31
    Jun 2011
    245
    Quote Originally Posted by A4_MaJiK View Post
    Thanks, Dav.
    no issues at all mate
    dav
  33. #32
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    480
    Quote Originally Posted by Macdoon View Post
    I test drove this car before I got mine. It has the 40/50 set up and 18" wheels but with B5 perches and 20mm spacers on the rear, it rubbed slightly on the rear due to the spacers.
  34. #33
    Macdoon's Avatar
    Essex
    1,569
    [QUOTE=ajax1976;1795552]I test drove this car before I got mine. It has the 40/50 set up and 18" wheels but with B5 perches and 20mm spacers on the rear, it rubbed slightly on the rear due to the spacers.
    Cheers fella, looks spot on
  35. #34
    spannah's Avatar
    Jul 2007
    N.London
    238
    35mm H&Rs
    Thanks for getting back to me, it looks really low for 35mm. I take it in this shot the wheels are 19s?
  36. #35
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    480
    Yip 19's. I'm not sure where H&R get the 35mm from, in every picture I've seen they look way lower and similar height to the 40/50 Eibachs.
  37. #36
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I looked at many pictures of the Eibachs vs the H&R and they are very similar. I have still yet to put the front springs on but the rear is nice and low with no rubbing. They are better than the stock and provide less harshness over bumps.
    Nathan
  38. #37
    spannah's Avatar
    Jul 2007
    N.London
    238
    Yeh that stance looks much lower than 35mm looks more like a 50mm drop all round. I love them wheels but i am stuck between these wheels and the S4 ones.
    If i get 19s do i need to get spacers for the rears? What ones do i go for, and will i get any rubbing on a full car?
  39. #38
    spannah's Avatar
    Jul 2007
    N.London
    238
    I dont have an S-Line but i have this exact model in black and i love the stance on the below;
    STUIWHITE's car
    I want these wheels in 19s
  40. #39
    V6 Quatt's Avatar
    Feb 2008
    783
    I would go for H&R 45mil drop had them fitted recentley along with RS4 ARB to my Quattro 3.0 TDI saloon. The car sits just right and they will settle and drop a little bit more i'm told. There is about 1.5 finger gap all around on 18's 19's going on soon.
    1. Ride comfort much improved,
    2. First thing I noticed, the ride less crashy smoother over bumps
    3. Car seems more leveled out and sterdy
    4. Stance is better
    Would recommend
    Hope this helps.
    Thanks, Dav.
    Torque the Torque
  1. Need help with sport springs
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2011, 09:28
  2. Help with fitting springs
    By phoenixv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th November 2009, 09:04
  3. HELP WITH SPRINGS TAPPING
    By vw754 in forum Awesome GTI
    Last Post: 16th September 2009, 12:10
  4. Help with fitting SYMPHONY double-din head unit
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 21:29
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
