Chris NottEM Tuning
Like Tree1Likes
  • 1 Post By Molnboman
Thread: Latest divertor valve??
    Pedro_keil's Avatar
    Dec 2012
    Deepest darkest Kent!
    19
    Hi all.
    Having the 2.0 TFSI lump in my EOS I upgraded the divertor valve to the latest model as the diaphragm piston had gone home.
    Does anyone know what year onwards thay need replacing on the Audi version.
    Also I would presume the DV would be the same across the VAG range?? If so I would be able to grab one from VW easier.
    A4 Avant (B7) 2.0 TFSI SLine Quattro TipTronic - Ooooooosh!!
    Molnboman's Avatar
    You are right to presume that's it's the same part number....I would have thought the EOS would have had the updated version I thought it only affected engines 2005 - 2009 'ish. Search thIs on the forum, there will be lots pf postings with the VAG part number. Check this out. Volkswagen OEM Diverter Valve Upgrade | my-gti.com
    BR
    A
    Pedro_keil's Avatar
    Dec 2012
    19
    Thats great thanks.
    The EOS an early '07 56 plate and yeah it was shot to bits when I changed it out. The lumpy tick over gave the game away so was thinnking get the A4 done before it dies.
    I'll get checking on the part numbers and no doubt will have to change it.
    Thanks again!
    Molnboman's Avatar
    Sorry, I can't find the link here with the part number, the VAG garage will know for sure....I did mine earlier this year, it was knackered and noticed a big difference after it was done.
    Good luck,
    A
    Pedro_keil likes this.
  1. a4 2.0t divertor valve
    By sewell10 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd March 2012, 06:58
  2. Forge Divertor valve kit FMFSITVR
    By RAPS3 in forum For Sale/Wanted - Audi Parts
    Last Post: 15th September 2011, 23:14
  3. 1.8T Divertor Valve issue?
    By jimbo_123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2010, 10:03
  4. Forge Divertor Valve / autobahn88 hoses
    By Twinkle666 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2008, 11:13
  5. Best Dumpvalve/Divertor Valve?
    By keendean in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2006, 16:53
