Latest divertor valve??
Pedro_keil
Deepest darkest Kent!
Hi all.
Having the 2.0 TFSI lump in my EOS I upgraded the divertor valve to the latest model as the diaphragm piston had gone home.
Does anyone know what year onwards thay need replacing on the Audi version.
Also I would presume the DV would be the same across the VAG range?? If so I would be able to grab one from VW easier.
You are right to presume that's it's the same part number....I would have thought the EOS would have had the updated version I thought it only affected engines 2005 - 2009 'ish. Search thIs on the forum, there will be lots pf postings with the VAG part number. Check this out. Volkswagen OEM Diverter Valve Upgrade | my-gti.com
BR
A
Thats great thanks.
The EOS an early '07 56 plate and yeah it was shot to bits when I changed it out. The lumpy tick over gave the game away so was thinnking get the A4 done before it dies.
I'll get checking on the part numbers and no doubt will have to change it.
Thanks again!
Sorry, I can't find the link here with the part number, the VAG garage will know for sure....I did mine earlier this year, it was knackered and noticed a big difference after it was done.
Good luck,
A
Reactions: Pedro_keil
