Sky InsuranceBadger5
    May 2011
    Suffolk
    310
    Powermax balance shaft replacement
    Hi guys
    Had a conversation with Dean at powermax this morning regarding replacing the balance shaft in the BLD 2.0tdi im looking at buying.
    Ive been weighing up is prevention better than cure, and the cost of the upgrade on top of the purchase price of the car needs to be considered
    Dean was very helpful full of good advice.
    He also mentioned as this model is the gear driven oil pump, to replace the balance shaft and hex is just a matter of dropping the sump and replacing the unit.. Is this correct??
    Has anyone done this or had it done to their 2.0tdi????
    Jul 2012
    56
    I used them when I wanted my BLB converting from chain to gear. They striped down the unit, converted what they had to so it would accept the new gears and checked the hex drive. They were very honest and said the the drive in the balancer shafts was the best condition they had ever seen given the mileage and just replaced the hex key with the new longer version.
    Not many people would have said that and carried on and replaced the hex drive, which is why I would recommend that you send it to them. Turn around was reasonable too, from me sending it to them to being back at the garage was just under a week and that included a weekend as well.
    May 2011
    Suffolk
    310
    Sorry guys. but could some knowlegable person quickly confirm if the balance shaft/hex can be replaced by just dropping the sump
    Would really help to know before i put a offer in on the car
    Jul 2012
    56
    Sorry missed the question, if its already gear driven then yes it's as easy as sump off, unit off, send it to them to do what they need to do, bolt back on, set up backlash on gears, sump on. It's maybe worth buying a new idle gear off them or audi as that's the one used to set up the backlash, it has a coating that wears off giving the right setting, at least then you will know 100% it right.
  1. 2.0 TDI oil pump / balance shaft failure?
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1 Week Ago, 22:03
  2. £2.2k to get balancer shaft system replaced on my 2005 2.0 TDi B7...fair price?
    By psychopomp1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th December 2012, 16:03
  3. following sticky 2.0 TDI oil pump / balance shaft failure? what year cars?
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th April 2012, 17:24
  4. BLB ENGINE A4 SLINE oil pump balancing shaft FAILURE
    By audiash in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th December 2010, 07:51
  5. Concerned about potential oil balance shaft failure...
    By daviemac11 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th July 2010, 20:17
