Sky InsuranceAH Fabrications
Results 1 to 22 of 22
    Nov 2011
    171
    DRL Headlights Queries
    Morning All
    Whilst having a look at the FK automotive sale i come across these
    Tuning FK Automotive | Headlight Daylight Set suitable for Audi A4 (type 8E) yr. 05-07 chrome | purchase online
    Now I do not know too much about DRL headlights but I am aware of the impending MOT regulation changes. If i were to buy and fit these headlights would my car pass an MOT ?
    Also, do the DRL's activate via the side lights ? Do they then essentially become the headlights ?
    Cheers in advance
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    DRLs replace your sidelights.
    As long as you use halogen bulbs and they are aligned correctly you won't fail an MOT with them
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Nov 2011
    171
    So how will these lights differ from xenon lights for example? Do these just use the same standard halogen bulbs that my standard lights use ? If that is the case i am assuming that they are not projector lights then ?
    Thanks for replying, much appreciated
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    They are projector headlights. What bulbs you put in them is up to you. But HIDs aren't technically road legal unless they are self levelling and you have headlight washers. You can fit normal halogen H7 bulbs or H7 HIDs into those housings, choice is yours.
    Nov 2011
    171
    So if i was to fit a H7 HID bulb, would i need ballasts to go with them or do they just operate the same way as halogens ? If i did fit them with standard halogen bulbs then i wouldn't need levelling motors and headlight washers would I ?
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Yes you would need ballasts with HIDs.
    No you wouldn't need auto levelling & washers with normal halogens
    Nov 2011
    171
    Brilliant, thanks for clarifying. Just one more thing, just noticed that the do the same headlights but for slightly cheaper. The only difference i can see if that the dearer ones say "with servomotor"
    Is the servomotor the auto levelling motor ? If so, i wouldn't need this if i just use standard halogen bulbs ?
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    To be honest I don't think any of them actually come with motors (but I could be wrong)
    On your dash there is a little knob which can be used to angle the headlights up and down slightly (for use when carrying a full load and the front of the car points more upwardss) to avoid blinding other drivers. Having just taken my FK headlights apart (supposedly 'with motors') I can see gearing in the headlight to potentially allow for the OEM motor to be removed from the original headlights & installed onto the FK ones, but haven't had a chance to try it yet.
    I believe from looking at it the same white hex nut which you turn to adjust the height manually is also adjusted by the motor. Where the motor comes from i am not 100% sure. I assumed that the english/german translation isn't brilliant and they wouldn't come with motors but that they would be ready to accept motors from the original headlights.
    If anyone ever bothers to reply to my thread about indicator bulbs... I'll let you know what happen when I finally get around to fitting the headlights.
    Nov 2011
    171
    Fantastic information once again pal. So you have bought some from FK as well ? I am assuming that the ones I mentioned earlier will be setup for RHD ?
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Oh, no this isn't the 'auto levelling motor'. If it's automatic it needs gyroscopes etc to automatically work out the angle of the car and adjust the headlight automatically. It could poeentially use the same motor, but I'm not sure?
    Adaptive bi-xenons adjust beam pattern based on speed and angle of the car, which is much more advanced that just an adjustment motor.
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    I did yeah, although I got the angel eye ones as personally I don't like the A5 DRL style.
    They can be changed RHD or LHD, there's a metal level inside the housing, easy enough to reach but better to be doe before fitting to the car
    Nov 2011
    171
    Yeah that makes sense. Really tempted to go ahead and order them now as they seem remarkably cheap ! My only reservation is around removing the bumper to fit them, don't want to damage the bumper fitting them
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    I've read it's failry straight foward, perhaps an extra pair of hands may be useful when repositioning, but I can't see it being very difficult. 2 out of 5 in a 'spanner' rating at most!
    Alternatively you could get a garage to fit them, maybe an hours labour? But for the cost I'd do it yourself... There are plenty of write ups if you search. Infact there's a sticky at the top of the B7 forum...
    Nov 2011
    171
    I am more than confident doing it myself but i have recently just had my bumper re painted so just don't want to damage it. Just being a bit of a wimp really ! I think i may order them !
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Go for it. Although I wouldn't expect to recieve them until the new year now as they ship from Germany...
    Just put a sheet down, you'll be fine!
    Jan 2012
    100
    i am also looking to get these headlights as they do seem a bargain.was going to get the more expensive auto levelling ones but to be honest its not going to make a difference as i dont have washers to make hids legal so the cheaper option it is.as for getting the bumper off its pretty straightforward as long as you have the front end up and both wheels off.recently done it to install an rs4 grill but it is quite time consuming
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Wheels shouldn't need to come off to remove the bumper... You only need to get at some screws in the arches...
    Also FK headlights aren't 'auto-levelling', as covered above
    Jan 2012
    100
    they dont have to come off but it makes life so much easier.for the sake of 5 mins to get the wheels off i would defo reccomend
    Jan 2012
    100
    as for auto levelling that wasnt what i meant.was talking about headlight adjustment...my bad
    Nov 2011
    171
    Just ordered these this morning, can't wait for them to arrive. Any idea how long delivery should take ?
    Jul 2012
    Quote Originally Posted by jjmurphy21187 View Post
    Are you talking about these ones jjmurphy?
    Tuning FK Automotive | Headlight Angel Eyes Set suitable for Audi A4 (type 8E) yr. 05-07 chrome | purchase online
    Im thinking of buying a set and wondering if they will be okay for our RHD cars, what you think?
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Delivery of mine took about a week and a half I think? And that was fairly close to Xmas. Would recommend you allow 2 weeks but you might be lucky enough to see them in a week...
  1. My aftermarket DRL headlights pics
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2013, 18:56
  2. Can you put a complete new style DRL headlight unit into a 2005 A3 Sportback?
    By ScouseA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th March 2010, 01:28
  3. New DRL / headlights
    By KKM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2008, 09:27
  4. DRL headlight function
    By cosmicblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2005, 12:48
