EM TuningVolks Autos
Like Tree2Likes
  • 1 Post By Chets
  • 1 Post By scotty76
Thread: Audi a4 wiper replacement
    Dec 2010
    212
    How to remove and refit b7 wiper blades
    Jan 2012
    KERNOW
    105
    Slide the end of the wiper arm/blade off if i remember right theres a tab on the top you have to push down and then the wiper blade will fall out. Replace the new blade and slide the plastic cap back.
    Chets's Avatar
    Jul 2010
    20
    It's a b***h to replace these wiper blades!
    Did mine yesterday, there's a clip that slides up, it's very tight so be patient - i broke the clips on the original wipers but my replacement Audi OEM one's came with clips.
    Should be a straight swap from there on.
    When sliding the clips back into place I found it easier to have the wiper flat against the windscreen and then slide the clip till it clicks into place.
    vitorcosta likes this.
    scotty76's Avatar
    Nov 2011
    Berkshire
    804
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Alternatively, check out Ravi's guide on how to do it during reruns of Top Gear on Dave.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Jul 2012
    55
    Quote Originally Posted by jdp1962 View Post
    Ravin it!!
    as said before its just a tab that lifts up or slides out (cant remember which) I just used the end of my key 5 mins later it was all done.
  1. Audi A3 8P Replacement Key
    By Tea Cosy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th October 2012, 14:45
  2. Do Audi replace broken wipers on a routine service?
    By psd99 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th August 2012, 20:50
  3. Aero wiper replacement
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2011, 18:43
  4. Replacing the Audi In Car Entertainment
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2004, 22:21
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
