JMB RetrofitsVolks Autos
    May 2011
    Aylesbury, Bucks
    38
    Windscreen washers
    Looking to change my washer jets to the fan jet style.
    Has any one done this if so which car did you get them off of
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    726
    Windscreen washers
    They come from a passat mate. Gonna do mine soon. Remember there's heated and non-heated ones. There's plenty of guys done it on here
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    chrisa4quat's Avatar
    Sep 2004
    897
    Windscreen washers
    It's a 7m0 or a 5mo part number iirc. Do a search you'll find loads on it. Have done this to mine. Still need to sort them properly as they don't fit in original cut outs too small. Mine are taped haha.
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    May 2011
    Aylesbury, Bucks
    38
    Will the ones off the MK5 fit do you know? Also are mine heated or is it the case of taking them out and seeing your myself?
    My car is a 2007 special s-line
    rizzini7's Avatar
    Jun 2011
    726
    Windscreen washers
    You should be able to see a cable if they're heated. They're quite easy to get out
    May 2011
    Aylesbury, Bucks
    38
    Just seen how the new set will fit. Dont know if i like the fact that they have to be glued in because there to small.
  1. Windscreen 'washer' jets - are your's rubbish too?
    By southpaw66 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2007, 11:36
  2. windscreen washer tank problem
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2006, 10:57
  3. Leaking Windscreen Washer Bottle......
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2005, 15:09
  4. Smell from windscreen washer
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2005, 20:03
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
