Sky InsuranceChris Nott
Results 1 to 14 of 14
    Dec 2011
    146
    Intermittent brake warning light on DIS when firing up my 2005 A4- B7
    Hi
    Every now and again (say 2-3 times a month) immediately after switching on the engine, i get the red brake warning light on the DIS but it always goes away after a second or two. Reading the manual this should happen if you attempt to drive the vehicle with the handbrake still on but obviously in my case the car is stationary. Any idea why this happens? The car is going to the Audi garage tomorrow for something else so i'll ask them to take a look at this as well.
    Dec 2011
    Glasgow
    195
    I had a similar problem with my passenger side rear light.
    The indercator bulb went so took the light out to change the bulb. I wasn't sure which holder it was and disturbed the red rear bulb instead. I changed the indercator all was ok but every so often I would get a dis warning me the passenger rear light not working.
    I would get out and tap the light and it would work. This went on a few weeks and then I got fed up of it so changed the bulb and since then no problems
    I suggest you change the bulb and check its seated correctly and succurly into the holder and light assembly
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Dec 2011
    146
    Thanks mate but which bulb(s) should be changed? Rear light bulbs have never been touched, i got oem bi-xenons fitted 6 months ago but this problem was happening before then.
    alpesh26's Avatar
    Mar 2011
    270
    Might be worth getting your battery tested. Mine used to do this and since I changed the battery the problem went away.
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    as above check batt
    Dec 2011
    146
    thanks chaps, will ask my audi dealer to check the battery
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,141
    Visit Craig Cull's Youtube Channel
    Quote Originally Posted by psychopomp1 View Post
    mine does this everything I start the car. Mines had a new battery and hasn't made a blind bit of difference. It also did it as I came off a roundabout this morning. Apparently it's something to do with the brake fluid reservoir. It needs changing. This is according to a couple of people on here. But... I've also been told its to do with the fact that there is no cover on the battery compartment. With the main wiring harness running all the way through the battery tray, apparently it can cause a short to the brake sensor when cranking over. I haven't managed to solve the problem yet as its too close to Christmas. Hope this helps would love to know audi's conclusion
    Dec 2011
    Glasgow
    195
    Hi I've just re read the original post. I obvuisily didn't read it correctly the first time lol I thought that it was refuring to the bulb out warning on the DIS. In actual fact I see that it's refuring to the red warning on the dis.
    My previous post was refuring to the bulb out warning in the dis. Sorry to cause any confusion
    Mods
    Full VCDs
    ctd
    Oct 2012
    Plymouth
    105
    mine does it now and again, checked everything and can't find a problem, sounds like a common problem so not that bothered about it now, just check fluid levels every couple of weeks just in case
    Jul 2012
    South London
    24
    I get this also on my avant.. Had pads checked as thought it may be warning on them getting low... They had at least 50% of meat left. I also don't have a cover over the battery and notice this happening in the mornings mostly.
    V6 Quatt's Avatar
    Feb 2008
    783
    Check fluid levels
    Torque the Torque
    May 2012
    Kings Lynn
    910
    Mine does this sometimes too. I dont have a battery cover and ive had both rear and front discs/pads changed very recently so battery cover or brake fluid level maybe the answer i guess
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I get the yellow '(O)' brake pad warning symbol come up sometimes (probably once a month) even though my brake pads aren't low. I have the battery cover fitted and my brake fluid level is fine.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    bez101's Avatar
    Jul 2008
    8,510
    whats with the battery cover ?
    the beeps can be from a weak battery nothing to do with not haveing a cover
  1. Intermittant brake warning light
    By richie_jones in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd June 2011, 17:53
  2. Help - Brake Warning light on DIS
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2010, 13:50
  3. HELP!! Red brake warning light on DIS screen at roundabouts
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2010, 12:43
  4. Brake Pad Warning Light (NO DIS)
    By BigG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2009, 20:32
  5. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
