Results 1 to 10 of 10
Thread: Lingering revs
    Dec 2012
    9
    Lingering revs
    Hi all,
    New to the forum. Bought my B7 A4 2.0TFSI Quattro about a week ago.
    Being reading up on this forum ever since.
    I read something about lingering revs but cannot for the life in me find the thread again.
    When sat at idle, if I were to tap the accelerator to about 2000rpm, the revs hold for a second or two instead of dropping straight back to idle. It seems to be especially apparent when the engine is cold.
    Can anyone confirm this as an issue or is it normal?
    Thanks,
    Adam.
    Jun 2010
    South Wales
    69
    Could be a dirty throttle body. The internal flap may be sticking. Worth a go as you can do it yourself. Even better would be to have it scanned.
    Dec 2012
    9
    Thanks.
    You reckon that could also be a reason for lack of throttle responsiveness? As some times when accelerating it doesn't seem to register until a half press of the throttle.
    Jun 2010
    South Wales
    69
    I had a petrol turbo golf and you'd be supprised at the amount of crap that can build up. Liberal amounts of carb cleaner got it all clean. But it may also be worth your while having it scanned. Perhaps a good injector cleaner to clean you system out too. To clean the throttle body out will only cost you a can of carb cleaner if you are handy with the tools.
    g00se's Avatar
    Nov 2010
    Reading
    265
    whats the mileage? could be a flywheel issue... ?
    my S4's started to do this a bit.. is really annoying. i just figured with 60k on the clock, that i may be up for a clutch and flywheel at the same time
    ive got my eye on a JHM lightweight jobbie
    JHM Lightweight Flywheel and Clutch Combo for 04 and up B6-B7 S4 - JH Motorsports Inc. - -- JHM.
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    Jun 2010
    South Wales
    69
    Depending on how you drive your car the clutch and flywheel should last longer than that.
    Dec 2012
    9
    Thumbs up
    Mines done 64k. TBH the clutch doesn't feel / sound to be doing anything it shouldn't. I normally drive fairly steady since I am trying to figure out what MPG I can get out of it. But obviously given a bit of a chance I do get the foot down.
    I only notice the lack of responsiveness when in neutral. Some times it responds immeadiately as I would expect, other times it is half press accelerator.
    Only noticed whilst queing down the M1 on the way home from work.
    I'll try have a look at it this weekend with a tin of carb cleaner. And check the PCV and DV while I am at it.
    Thanks for your help.
    Jan 2011
    111
    Mine has always done this, I was told it's an "anti stall" system!! it made sense to me...
    Nov 2012
    I also have this in a 56 2.0 TFSi seems strange
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,259
    Re: Lingering revs
    Had this on my old one. Was carbon build up on the throttle body, £100 later and problem went.
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
  1. Hesitation through revs
    By imported_Robbyc in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 17:16
  2. engine goes flat at 3000 revs
    By ratty in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd May 2004, 02:21
  3. S3 rev hang-up
    By S3DCT in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2003, 20:58
  4. Rev Matching
    By amoffat in forum Detailing
    Last Post: 3rd July 2003, 10:30
  5. rev limit?
    By Administrators in forum General Technical / How To
    Last Post: 3rd May 2003, 00:35
