Volks AutosChris Nott
Results 1 to 7 of 7
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,753
    brake lights stuck on?// !
    hi there!
    got a slight problem regarding the barge!
    i have not used the car at all today, and its been in the garage since yesterday.
    just been into the garage to get some refreshing beers out of the fridge and noticed that there was a red glow coming from under the garage door.
    opened the garage door to see the brake lights were stuck on!
    and i dont know how long they had been like that!
    so to be on the safe side i started the engine to see if it would, and to put a bit of charge back in the battery.
    it did so ok on that score.
    i noticed this problem a couple of weeks ago when scraping ice off the windows, gave the brake pedal a bit of a dab and the brake lights went off! so just dismissed this as something frozen.
    so now when i noticed it this evening in the garage with no ice about i am starting to worry a bit, as i dont want to get stranded with a flat battery somewhere!
    so if any of you guys can offer some advise on this intermittent problem i will be mucho grateful!
    i dont have vcds and hoping its a common quick fix like a sensor or switch maybe!
    thanks in advance, chez!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    ​Hopefully its something really simple Chez and you get it sorted out quickly. x
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    you need a new brake light switch
    easy to change and not a lot of £££ use OEM
    its on the brake pedle at the top
    so lower dash panel needs to be removed
    to turn them off for now unplug the switch or its gona kill the batt.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,753
    aah! nice one bez!
    i was hoping it would be something simple like that!
    i keep going out every hour and checking it and it seems to be ok!
    looks like a trip to TPS tomorrow it is then!
    is there any guides on how to do this do you know?
    bez101's Avatar
    Jul 2008
    8,472
    no guide i know of maybe 1 on here somewhere or google
    but its very easy
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,753
    its ok mate all sorted!
    £10.30 or something from TPS and found a guide on here and your right, was a 10 minute job and a doddle!
    all is good!
    bez101's Avatar
    Jul 2008
    8,472
    Glad you sorted it
  1. Please help! brake lights stuck on, fuse blowing! a3 2.0 tdi 2004 8p
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2014, 21:38
  2. Brake light stuck on
    By Audi-Power in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2012, 17:07
  3. replaced bulb and now brake lights stuck on !?
    By stu_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2011, 23:04
  4. Brake Lights Stuck On!!!!
    By mel_man in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2011, 18:07
  5. Help!my 1st A3&brake lights are stuck on
    By dogstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2006, 20:36
