Monster MotorsportVolks Autos
Results 1 to 13 of 13
    Oct 2012
    Leicester
    23
    Low oil level warning 2.0TDi
    Hi all,
    I have a 57 2.0 tdi 170 and get the low oil level intermittently but usually come on after a long drive of an hour or more. I could then park the car on the drive and the next morning with a cold engine, the warning will appear when I switch the ignition on and will remain on. If I don't start the car and check the level on the dip stick, it's bang on the max mark. Replace the dipstick and turn ignition on again, the warning has gone. It will probably remain normal until I drive for an hour or so again.
    Anybody any idea what's going on?
    Pete
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,907
    Oil level Sensor or sensor cable broke damaged f**ked.
    I think that low oil is a red light and sensor issue is an orange one. Anyone?
    JSD 2.59
    Synergy-Solutions
    Oct 2012
    Leicester
    23
    Quote Originally Posted by sidibear View Post
    ok that's great.. Well not great but at least it's perhaps not a prelude to something serious. Unless you tell me to replace a sensor is a shed load of £££'s
    Thanks for the reply!
    Apr 2012
    43
    Mines did the same. Orange light was the sensor. Replaced and fine since
    Aug 2011
    south aberdeenshire
    26
    I had the same car. Is it the orange/yellow oil warning light that is coming on? This is the low engine oil level warning and as the light is intermittent it may be a faulty sensor but I would get it quickly checked. There is also a red warning light which is the low engine oil pressure. If this comes on switch off the engine straight away and get it diagnosed. Whatever get it checked out.
    Oct 2012
    Leicester
    23
    Quote Originally Posted by mearnsA4 View Post
    Thanks for the replies, yes it's the amber caution regarding the oil level, no oil pressure lights. I'll get it checked out. Cheers
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    Sounds like the sensor (had the same problem on mine) part is around £90 and located near the sump plug.
    Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    1,907
    Mine was a break in the wire, worth a try metering the cable before you shell out for a new sensor.
    JSD 2.59
    Synergy-Solutions
    Oct 2012
    Leicester
    23
    Hi again.
    The car was still under warranty with the dealer so I took it back to them last week to have the sensor replaced. I told them the symptoms described in post #1 when I left it for the week. Called them today and they said the oil was low and topped it up ffs. Am I being a twat and not reading the oil level correctly? Or am I being fobbed off? I told them that all you have to do it lift the bonnet and re-seat the dip stick and the warning will disappear for about 90mins worth of constant driving.
    i_786_i's Avatar
    Aug 2012
    57
    Talking
    Quote Originally Posted by Iknownothing View Post
    Hi again.
    Sounds like they are trying the easy route first. If the problem reappears then you know its not your ability to read a dipstick, and theirs for being a dipstick!
    Oct 2012
    Leicester
    23
    Quote Originally Posted by i_786_i View Post
    Sounds like they are trying the easy route first. If the problem reappears then you know its not your ability to read a dipstip, and theirs for being a dipstick!
    My worry is that I left it with max oil and now they've topped it up. I can only assume one of us is misreading the stick. I assume the max level is the tiny max line inbetween the two bubbles on the stick, so I'm guessing they've filled it up to the top of the upper bulge? Which is correct?
    If they have indeed over filled it, could that cause any problems?
    Sorry for being a pleb.
    i_786_i's Avatar
    Aug 2012
    57
    Being slightly over the max mark will make no difference. Upto the bulge is where the max mark is and if the sensor is working correctly, error should appear when oil in below the min mark.
    If they heavily over topped it, then you should notice heavy smoking out the back and a red oil pressure light.
    Oct 2012
    Leicester
    23
    Ok cheers for your help.
  1. Low Washer Level Warning
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2009, 07:40
  2. Oil Level Warning Light
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2008, 06:40
  3. Low oil level warning
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2008, 17:56
  4. low oil dash warning light not clearing!
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th March 2008, 12:53
  5. A4 B7 2.0TDi Low Oil Level Warning Light
    By stedes in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd November 2005, 18:31
